obd0 or obd1 for a 94 civic 4door
Old Aug 10, 2006 | 08:21 AM
lol_on_v8s's Avatar
Default obd0 or obd1 for a 94 civic 4door
im about to get a 94 civic 4 door.. and just wondering if a 93 ls motor will fit in it with no major mod.. and i wanna know if i can use the same wireharness from the civic im about to get with an obd0 ls.. thanks in advance...
Old Aug 10, 2006 | 08:23 AM
philosofy1's Avatar
Default Re: obd0 or obd1 for a 94 civic 4door (lol_on_v8s)
corect me if i'm wrong, but if that's a OBD0 ls then no you cannot use the same wire harness. your civic is a 94, that year they came OBD1.
Old Aug 10, 2006 | 08:28 AM
Bulli Kid's Avatar
Default Re: obd0 or obd1 for a 94 civic 4door (philosofy1)
your car is obd1. you can only put that or higher like obd2
you may not go lower to obd0
Old Aug 10, 2006 | 08:29 AM
lol_on_v8s's Avatar
you replied fast.. thats kool.. but yea.. i wasent sure if a eg civic came with obd1 or 0.. thats why i ask.. so ima have to use an dc2 integra harness then.. right..
Old Aug 10, 2006 | 08:30 AM
lol_on_v8s's Avatar
oh.. thanks.. what do i need to so if i used a 94 and up integra ls i should be good right....
Old Aug 10, 2006 | 08:38 AM
Syndacate's Avatar
Default Re: (lol_on_v8s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lol_on_v8s &raquo;</TD></TR><TR><TD CLASS="quote">oh.. thanks.. what do i need to so if i used a 94 and up integra ls i should be good right....</TD></TR></TABLE>
yeah but after a certain year they started making ODB-2..so you'll need an ODB-2 conversion harness, but u'll still be okay
Old Aug 10, 2006 | 08:47 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
yeah but after a certain year they started making ODB-2..so you'll need an ODB-2 conversion harness, but u'll still be okay</TD></TR></TABLE>
you can use 94-95 integra, they are OBD1. not sure exactly when they switched to the OBD1 ecu before this.
Old Aug 10, 2006 | 09:36 AM
95lscivic's Avatar
Default Re: (philosofy1)
that is not completely true, you can use an obd0 if you have an obd1 dizzy, and injectors.
Old Aug 10, 2006 | 09:41 AM
philosofy1's Avatar
Default Re: (95lscivic)
hmmm....good to know!
Old Aug 10, 2006 | 02:32 PM
92_VX_EG's Avatar
A '93 LS should be OBD1 already... I think they switched to the OBD1 PR4 in '92. You can use your stock civic wiring harness, you don't have to use the Integra one.
You said no major mods... I'm not sure what you mean by that so: you'll need the mounts off a 94+ Integra, shift linkage off a 94+ Integra, the rear tranny bracket off the 94+ Integra, the a/c bracket, the front tranny bracket, axles, intermediate shaft, OBD1 ECU, etc..
Old Aug 10, 2006 | 05:14 PM
ablack934doorcivic's Avatar
Default Re: obd0 or obd1 for a 94 civic 4door (92_VX_EG)
I AGREE
Old Aug 10, 2006 | 05:19 PM
95lscivic's Avatar
Default Re: obd0 or obd1 for a 94 civic 4door (ablack934doorcivic)
very true they did in 92 i didnt catch that earlier, good eye. 92-95 are obd1, 96 + is obd2.
Old Aug 10, 2006 | 06:28 PM
2to5coupe
Guest
Posts: n/a
Default Re: obd0 or obd1 for a 94 civic 4door (95lscivic)
a 93 ls is OBD1 For sure. the tranny is Cable thought even thought civics went hydro in 92 tegs didnt till 94 and obd1 ran til 95 then obd2A in 1996 obd2B in 99
Old Aug 11, 2006 | 05:14 AM
lol_on_v8s's Avatar
yes.. that what i meant to say... the civic trans is hydro not cable like my ls.
Old Aug 13, 2006 | 01:15 PM
lol_on_v8s's Avatar
aight thanks for the info.... all i need now is to grab me a 93 ls... thanks again
bacnoonoi
Jun 2, 2007 11:23 AM
Chewy Built !
Apr 25, 2007 07:20 PM
honda_racer1986
May 25, 2005 09:00 AM
kwil6666
Mar 29, 2004 01:01 PM
