B18C1 torque spec verification... and order?
Old Aug 10, 2006 | 07:13 AM
miahmouse's Avatar
Default B18C1 torque spec verification... and order?
For the cam cap/holder bolts...
12mm: 20 ft/lbs
10mm: 7.8 ft/lbs
(13)(09)(5)(1)(3)(7)(11)
(14)(10)(6)(2)(4)(8)(12) Intake Cam side
(14)(10)(6)(2)(4)(8)(12) Exhaust Cam side
For the Cylinder head...
22ft/lbs then 63ft/lbs
8, 4, 2, 6, 10 <---intake order
7, 3, 1, 5, 9 <---exhaust order
Modified by miahmouse at 12:11 PM 8/10/2006
Old Aug 10, 2006 | 08:19 AM
Luserkid's Avatar
Default Re: B18C1 torque spec verification... and order? (miahmouse)
The Torque is right, and the order is right. Only thing is what i do to start my caps is i make 1 on the intake and 2 on the exhaust go down first (not torqued just down) then intake 7, exhaust 8, intake 9 then exhaust 10. After that then i torque in the order you mentioned. This way it allows the caps dowel pins to seat flush across the head.
Old Aug 10, 2006 | 08:36 AM
miahmouse's Avatar
Default Re: B18C1 torque spec verification... and order? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">The Torque is right, and the order is right. Only thing is what i do to start my caps is i make 1 on the intake and 2 on the exhaust go down first (not torqued just down) then intake 7, exhaust 8, intake 9 then exhaust 10. After that then i torque in the order you mentioned. This way it allows the caps dowel pins to seat flush across the head. </TD></TR></TABLE>
I was thinking the same thing... thanks again
redlinekink99
Feb 20, 2009 02:01 PM
DC_RaceR
Apr 25, 2007 01:45 PM
GSR4U2NV
Jan 31, 2006 03:43 PM
EK FLY
Jun 5, 2005 08:04 PM
xfrankx
May 8, 2005 04:17 AM
