obd1 to obd1
I am after obd1 to obd1 straight through wiring harness , as i don't want to hack my stock wiring harness.
Any ideas where i can get one ?
Modified by 94vtirozguy at 9:29 PM 8/11/2006
a harness that will sit between the end of the stock harness and other end goes into ecu.
straight through means none of the wires are crossed over and in same pin configuration.
This will allow me to cut the new harness without me modifying the cars stock harness.
So you're basically wanting to extend the wires from the stock harness so you can splice into the extension instead of the stock harness to keep from damaging it..
<-- Understands...
Good luck though...
Heh
<-- Understands...
Good luck though...
Heh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 »</TD></TR><TR><TD CLASS="quote">So you're basically wanting to extend the wires from the stock harness so you can splice into the extension instead of the stock harness to keep from damaging it..
<-- Understands...
Good luck though...
Heh</TD></TR></TABLE>
yep . correct
if i can't get one, i will make one myself.
<-- Understands...
Good luck though...
Heh</TD></TR></TABLE>yep . correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludecz »</TD></TR><TR><TD CLASS="quote">Give these guys a call!
http://boomslang.us/</TD></TR></TABLE>
thanks. they have them
