audio video gurus Help needed!!!!PLZ
Ok guys i have a 06 accord i have the factory head unit and im running a 12 inch audiobahn sub with a mtx amp since im using the factory deck im using the line outs that the amp allready came with... Everything sounds perfect and im onto my new project.. I was hoping i could get a 6.5 headrest monitor or somin equivalent so i can put it where the stock little cubby is on the accord.. My question is, is there anyway for me to hook up my audio off my stock head unit speakers for my screen/ playstation.. Since i have the rcas on the amp will that work as a audio signal?? I have searched and i was also wondering if a
FM Modulator By AUDIOVOX will work this is the Product Description
Would you not like your car video system to play its sound through your factory installed stereo system, rather than setting up a separate sound system for your car video? With the Audiovox RF Modulator FMM100A you can do just that. The Audiovox RF Modulator FMM100A allows the sound from the Video Source to be played through your vehicle?s factory stereo. You must wonder how that can be done. Well, it is quite simple. The Audiovox RF Modulator FMM100A connects to your factory Car FM Radio Antenna and makes this possible. The key components to this system include an FM Modulator, RCA Signal cables and turn-on Switch. There is an AUX input too.
If theres any way to do this i would really apreciate the help...
Pat
Modified by 06_accord_k24a4 at 12:40 AM 8/10/2006
Pat
Dark_Knight
Mar 7, 2004 09:45 PM
