act 15k clutch starting to slip All new clutch or just disk? $150 or $500+
Old Aug 9, 2006 | 08:39 PM
harrykong's Avatar
Default ACT 15k clutch starting to slip All new clutch or just disk? HELP!!!!!PLEASE
Hi-
So im going to replace me clutch soon "with in this month" my clutch is starting to slip this past month after about 15k miles on it. I was wondering if i should replace the whole clutch or just throw out bearing and disk.
I wanna save money but i dont mind buyin the whole kit if I ONLY need to. I love the clutch its been pulling hard for a long time.
I was kinda hoping the pressure plate was still good and just go with the bearing and disk 150 looks alot better then 500+ your opion would be great thanks guys
Modified by harrykong at 9:19 PM 8/13/2006
Old Aug 13, 2006 | 08:18 PM
harrykong's Avatar
Default Re: act 15k clutch starting to slip All new clutch or just disk? $150 or $500+ (harrykong)
Bump i NEED HELP PLEASE
Old Aug 14, 2006 | 08:21 AM
D-meet07's Avatar
If the teeth on the plate look good(which it probably does) replace the disc.
Old Aug 14, 2006 | 08:46 AM
Nors's Avatar
Why did the clutch wear out so fast? If the pressure plate wore out the clutch, replace it. Its common practice to replace everything at once. Especially in a case of a premature wore out clutch. Unless its from your driving style and you know this for sure, I would replace everything, inlcuding pilot bearing.
Old Aug 14, 2006 | 11:17 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
hmm I have about 100K on my Clutchmasters stage 1, and I was told I could just replace the disc and keep using the pressure plate. Every now and then it'll slip a little when I start off in 1st gear, but never any other times.
Old Aug 14, 2006 | 01:02 PM
Nors's Avatar
Default Re: (PatrickGSR94)
Patrick, I would personally buy everything. BUT you can just replace the disc, but then when something else fails, you either had to do the job again, or fork out the money for the same labor.
It is very cost effective to replace it all at once, since the labor will be like .5 hours more tops.
Old Aug 14, 2006 | 07:48 PM
Community Builder
Default Re: (Nors)
labor haha what's that? my own muscle!
Me and my buddy put in my Clutchmasters Stage 1 clutch and light flywheel about 3 years ago (100K on them already! ), and now I was planning on just replacing the friction disc and the steel friction surface on the aluminum flywheel.
If the clutch disc has not completely worn down yet, then the pressure plate should still be okay to use right?
Old Aug 14, 2006 | 08:02 PM
POE's Avatar
POE
u put the clutch in, and eithor did not get the flywheel or pressure plate re surfaced.... or you beat the hell out of the clutch soon as it was installed, you need to do a wear in period of 500 miles, before abusing it
Old Aug 14, 2006 | 08:05 PM
D-meet07's Avatar
yes. Replace the disc and your good. Think about how often you change a factory clutch kit. About every 30k or so depending on driving. Clucthes are one of those things that dont wear out that often. Plus an aftermarket clutch is like 30 times more durable.
Old Aug 15, 2006 | 04:17 AM
Community Builder
Default Re: (D-meet07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-meet07 &raquo;</TD></TR><TR><TD CLASS="quote"> Think about how often you change a factory clutch kit. About every 30k or so depending on driving. </TD></TR></TABLE>
my original clutch lasted till 135K miles before pieces broke off the disc. My brother's del Sol original clutch lasted over 160K before the car wouldn't even move any more.
Old Aug 24, 2006 | 06:44 AM
harrykong's Avatar
Default Re: ACT 15k clutch starting to slip All new clutch or just disk? HELP!!!!!PLEASE (harrykong)
**** now i got mixed emotions *** it ill just replace the whole thing thanks guys
Old Aug 24, 2006 | 02:32 PM
POE's Avatar
POE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harrykong &raquo;</TD></TR><TR><TD CLASS="quote">**** now i got mixed emotions *** it ill just replace the whole thing thanks guys
this time re-surface the flywheel and pressure plate. and do not beat on the clutch(wear it in smoothly, or dont drive crazy, no dropin the clutch at 5 k) wear it in for 500 miles. then have fun, but be safe!
Old Aug 26, 2006 | 07:14 AM
harrykong's Avatar
Default Re: ACT 15k clutch starting to slip All new clutch or just disk? HELP!!!!!PLEASE (POE)
i love you
MiNeSEK
19
May 11, 2013 12:05 AM
BigAnteg
May 24, 2010 01:25 PM
maxboost94
Sep 20, 2007 07:40 PM
boston's_rex
10
Jun 21, 2006 02:11 PM
Cyber ITR
Nov 24, 2003 12:08 PM
