tranny removal problems
i have a 95 ex coupe d16z6 and im trying to take the tranny off to put my 6 puck in. i took all the tranny bolts and the mount bolts and removed the axles and starter and the flywheel plate. i was wondering is the flywheel plate supposed to come off? and do i have to drop the shiftlinkage to drop the tranny? help is very appreciated!
You will need to remove all the bolts and the shift linkage.
don't forget the rear, the side, and the front mounts.
also the tranmission may need some prying to get off.
The dowel pins are often tight
ok well i think the shiftlinkage is the problem because it is a little pryed but wont crack. anyone know where to buy some syncromesh either? thanks
well, i would recommend disconnecting the shift linkage from the tranny...makes things alot easyer to work with. also, yes that plate can come off...im assuming your talking about the flywheel inspection plate
Don't forget the brackets between the block and the trans.
The shift linkage will not cause the trans not to seperate form the block. You have something else connected still.
In my experince a slight wiggle will seperate the trans form the block.
yeah the black plate on the bottom i got like 4 bolts off but it doesnt come off.....oh well i will try to find more blots to that...which brackets?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sLoWrAcEr »</TD></TR><TR><TD CLASS="quote">which brackets?</TD></TR></TABLE>
There are 2 brackets that connect the engine and trans. on the bottom next to the oil pan...should be 17mm heads into the trans and 12's in to the bottom of the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslowly93 »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Dig the avatar
From Othello?
Dig the avatar
From Othello?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C »</TD></TR><TR><TD CLASS="quote">Dig the avatar
From Othello?</TD></TR></TABLE> actually from oak harbor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslowly93 »</TD></TR><TR><TD CLASS="quote"> actually from oak harbor
Ahhhhh, thought you might be an east side outcast like me.
That tranny off yet???
</TD></TR></TABLE>Ahhhhh, thought you might be an east side outcast like me.
nope too dark and too many mosquitos tonite...im in nova.....not allowed to work on cars after 12......fairfax county is sooo gay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sLoWrAcEr »</TD></TR><TR><TD CLASS="quote">nope too dark and too many mosquitos tonite...im in nova.....not allowed to work on cars after 12......fairfax county is sooo gay
Damn that sucks, good luck tomorrow, just take your time and double check everything.
</TD></TR></TABLE>Damn that sucks, good luck tomorrow, just take your time and double check everything.
ok, just a quick question since we are on the topic of tranny removal...I reinstalled a z6 tranny to my y7 motor but now oil leaks...I've checked all the bolts and linkage. Also only put 2 quarts of oil. But still leaks..what's wrong?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBR_15 »</TD></TR><TR><TD CLASS="quote">ok, just a quick question since we are on the topic of tranny removal...I reinstalled a z6 tranny to my y7 motor but now oil leaks...I've checked all the bolts and linkage. Also only put 2 quarts of oil. But still leaks..what's wrong?</TD></TR></TABLE>
Where's is the leak? Remember, everything flows downhill...so start looking at the top and work your way down 'till you find the source. You wouldn't believe how many leaky cam seals have been called "leaky trannys" by my customers.
rice a roni
11
Apr 26, 2006 05:10 PM
1 sick ej
Nov 20, 2004 09:29 AM
triggerX
Apr 24, 2004 12:03 AM
