oil light problem?
Old Aug 9, 2006 | 08:04 PM
oak1now's Avatar
Default oil light problem?
hey guys my oil light just turn on today so i added some oil and still nothing the light stayed on and it doesnt want to go away it has oil the weird thing is when i accelarate the oil light stars blinking what can i do let me know what you guys think it is maybe a sensor? thanks in advance
Old Aug 9, 2006 | 09:14 PM
NAiL05's Avatar
Well if your oil levels are normal next thing I would check would be your oil sensor. That coulda gone bad it should be located around the top of your oil filter.
Old Aug 9, 2006 | 10:56 PM
thatasiankidtony's Avatar
Default Re: (NAiL05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAiL05 &raquo;</TD></TR><TR><TD CLASS="quote">Well if your oil levels are normal next thing I would check would be your oil sensor. That coulda gone bad it should be located around the top of your oil filter.</TD></TR></TABLE>
Ditto!
Old Aug 9, 2006 | 11:04 PM
oak1now's Avatar
Default Re: (thatasiankidtony)
would i be able to find it at auto zone or pep boys?
Old Aug 9, 2006 | 11:19 PM
iam7head's Avatar
Default Re: (oak1now)
you want to go junk yard or dealer, they doesn't usually fail that easily.
in most case the car get junked before they fail.
test it with a multi-meter first and see if you are getting consist ready
Old Aug 10, 2006 | 01:56 AM
Jmumblez2001's Avatar
Default Re: oil light problem? (oak1now)
OAk,
I were you the first thing i'd do is stop driving that car, 2nd connnect an oil
pressure gauge to your oil pressure switch to register for oil pressure, if you ain't got no PSI most likely your oil pump is bad.
good luck
Old Aug 13, 2006 | 05:49 PM
oak1now's Avatar
Default Re: oil light problem? (Jmumblez2001)
where would the oil pump be at? and how do i check it?
Old Aug 13, 2006 | 05:52 PM
hondadude's Avatar
probably the oil sump pickup screen is plugged up with sludge from never changing the oil.
happens all the time on those 82 accords
oak1now's Avatar
hey i put a new sensor but now the light just stays on how do i check the sensor?
Old Aug 13, 2006 | 06:02 PM
Seeds's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmumblez2001 &raquo;</TD></TR><TR><TD CLASS="quote">OAk,
good luck</TD></TR></TABLE>
dido... check the pressure, and there isnt really a way to check that switch on your own, honda can do it, but it will cost you. You can check to make sure there is power to it with a volt meter, but that is about it!
Old Aug 13, 2006 | 06:19 PM
BLKFLSH's Avatar
Default Re: oil light problem? (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">probably the oil sump pickup screen is plugged up with sludge from never changing the oil.
happens all the time on those 82 accords</TD></TR></TABLE>
This is what I think is the problem too. Whatever year your car is.
95_red_dc
Apr 2, 2008 06:17 PM
msinsky14
Nov 26, 2006 06:57 AM
Roi
22
Nov 17, 2005 10:01 PM
ludeman92
Nov 10, 2005 11:02 AM
hillbillybob
Feb 9, 2005 07:05 AM
