A/C Belt removeal to facilitate Alternator belt installation Question
Old Aug 9, 2006 | 08:02 PM
roadhead's Avatar
Default A/C Belt removeal to facilitate Alternator belt installation Question
Ok, I finally got the alternator back from the shop with a brand new diode plate. While it was in the shop we had to move the car out of the garage it was in, so I got some more practice taking the wheel hub off the axle today. We did manage to get the alternator into the bracket, and put the front suspension back together, but now we've run into a new problem.
How to get the new alternator belt on. Obviously the A/C compressor belt has to come off, and it looks like there is a tiny nut hiding under the motor mount that would adjust what looks like an idler pulley up and down, but turning it left didn't seem to help, nor did turning it right until it got too tight to turn anymore. Of course my Chitlon's book doesn't offer anything worthwhile. I had an idea to actually remove the nut thats holding that top pulley on, the one on the bolt that goes THROUGH the 10mm adjuster nut we'd already been playing with, but it was late and we were tired so I thought I'd ask the experts before we broke something.
So guys, how do you properly loosen and remove the A/C pull on an 89 CRX Si so you can put your new alternator belt on?
Thanks for all your help so far, I know we'll get my baby back on the road soon now.
Old Aug 9, 2006 | 08:49 PM
Paxil4x4's Avatar
Default Re: A/C Belt removeal to facilitate Alternator belt installation Question (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">1. Cut AC belt.
2. Remove AC components
3. Enjoy =P</TD></TR></TABLE>
Gayest advice of the day
Old Aug 9, 2006 | 09:20 PM
doublethink's Avatar
Default Re: A/C Belt removeal to facilitate Alternator belt installation Question (packthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by packthis &raquo;</TD></TR><TR><TD CLASS="quote">Gayest advice of the day </TD></TR></TABLE>
haha
Old Aug 10, 2006 | 09:20 AM
roadhead's Avatar
That was my first suggestion as well, but I do live in Texas, and its been one hell of a hot summer, and I'd hate to give up my working Air Conditioning...
Come on guys, I know someone has the info I need...
Old Aug 10, 2006 | 09:24 AM
Loserkidwac's Avatar
Default Re: (roadhead)
Someone correct me if i'm wrong but there is 2 nuts that need to be lossened fr the AC belt adjustment, one is the one i believe you are talking about which is the acctually pulley adjust ment but the one in the center of the pulley also needs to be loosen to allow it to move, the adjuster just moves the pulley up or down and keeps it from slipping while the one in the center is the what holds it in place
I don't have AC but i believe thats how we did it on my friends teg...
Old Aug 10, 2006 | 12:35 PM
ludesrv's Avatar
If you have air tools. Throw (I think) a 19mm on the crank pulley and take it off, apply belts, put it back on. Will take you 10-15 minutes haha.
Ghetto, but works!
Old Aug 10, 2006 | 12:40 PM
CRXBart's Avatar
Default Re: (ludesrv)
What is AC?
Old Aug 10, 2006 | 12:48 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (Loserkidwac)
Just did it in my Civic, had to loosen the adjuster nut on top as well as the locknut on the pulley itself
Old Aug 10, 2006 | 01:01 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote"> loosen the adjuster nut on top as well as the locknut on the pulley itself</TD></TR></TABLE>
Loosen the 14mm nut in the middle of the pulley first,
Then loosen the 10mm adjuster bolt...
That will move the pulley and create slack to remove the belt..
Modified by 88DXCRX at 4:12 PM 8/10/2006
Old Aug 10, 2006 | 04:42 PM
No2Pencil's Avatar
Old Aug 13, 2006 | 06:53 PM
roadhead's Avatar
Default Re: A/C Belt removeal to facilitate Alternator belt installation Question (No2Pencil)
Thanks wizco and 88DX, I was able to get everything squared away and finally drive the car home from my buddies house.
OOOtony
Sep 25, 2007 07:56 PM
integracing86
Oct 26, 2006 01:52 PM
Import_Dumbass
10
May 21, 2006 03:59 PM
Fook_me_honda
Sep 21, 2005 01:28 AM
failed
Sep 4, 2005 05:59 AM
