FITV
Old Aug 9, 2006 | 07:06 PM
importtuner07's Avatar
Default FITV
if i clean the FITV would i need to replace the intake manifold gasket? thanks for your help
Old Aug 9, 2006 | 07:51 PM
1slowhatchie's Avatar
Default Re: FITV (importtuner07)
why are you cleaning your fitv? is your car reving up and down?
Old Aug 9, 2006 | 07:56 PM
wheelmanbg's Avatar
Default Re: FITV (1slowhatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowhatchie &raquo;</TD></TR><TR><TD CLASS="quote">why are you cleaning your fitv? is your car reving up and down? </TD></TR></TABLE>
+1
To answer your question: No, you don't have to take off the IM, therefore, no need to replace gasket
Old Aug 9, 2006 | 08:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importtuner07 &raquo;</TD></TR><TR><TD CLASS="quote">if i clean the FITV would i need to replace the intake manifold gasket? thanks for your help</TD></TR></TABLE>
your probably thinking of your throttle body gasket,i would cause when you take it off most likely the gasket would get messed up.
Old Aug 9, 2006 | 08:14 PM
its when i start it it ideals like at 500 or 600 until i rev it then it will ideal kinda right but ideal up and down and on the fourm the person takes off the IM so i thought i would but could it runin like that because my spark plugs are fouled out from gettin water in my intake. thanks again for any help
Old Aug 10, 2006 | 10:07 AM
wheelmanbg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importtuner07 &raquo;</TD></TR><TR><TD CLASS="quote">its when i start it it ideals like at 500 or 600 until i rev it then it will ideal kinda right but ideal up and down and on the fourm the person takes off the IM so i thought i would but could it runin like that because my spark plugs are fouled out from gettin water in my intake. thanks again for any help</TD></TR></TABLE>
I did not really understand what you said
BTW it's "idle" not "ideal"
From what I did gather you're not having problems with your FITV. You need to look into your IACV
94lspower
May 9, 2007 02:53 AM
RACEPAK
Nov 2, 2005 08:47 AM
Seedc2
Apr 1, 2005 09:51 PM
eg6T
Oct 30, 2004 04:40 PM
