what does this do exactly???
Old Aug 9, 2006 | 06:36 PM
h22apwrdcivic's Avatar
Default what does this do exactly???
in this picture...listed as #24. it is the air assist solenoid valve. i have two issues
for one i broke the side port off and have no clue where the hose is or where it is to go from to that port.
TWO since that port broke i bypassed this complete valve. now the car overheats when i sit in traffic. i highly doubt it has any effect through this valve as it does not open into the coolant....it is sealed and opens at certain temps. yet what will it hurt if i leave it bypassed.
bit more info on the car.....
i acquired the car from a good friend that got tired of it sitting in his driveway (sat for 4 years) it is a 2000 model with only 28xxx miles on it...all original. the car was stolen shortly after he got it....and shortly after we put a body kit on it, wheels, suspension, exhaust, leather conv. kit on interior. so of course all that was stolen. so i basically got it as a rolling chassis with some interior piecing it back to life along the way. now it is my daily driver ( still no title but working on it) thus why i need to work out the overheating problem. i did a leak down test all is good coolant is not leaking out until it overheats then it bubbles out of the overflow. unless it just needs a good system cleaning from sitting for 4 years..... throw me ideas, concerns...possibilities....experienced issues...anything please help....hey if you have the valve lemme know. thanks
Old Aug 9, 2006 | 07:00 PM
NA_H22_Ej's Avatar
Default Re: what does this do exactly??? (h22apwrdcivic)
#24 looks like a fan switch, that cuts on the radiator fan when your thermostat opens
Old Aug 9, 2006 | 07:07 PM
it is not electrical at all. and this is a stock y8 motor in the 2000 civic ex.
Old Aug 9, 2006 | 07:21 PM
96-EJ6 B18C's Avatar
Default Re: (h22apwrdcivic)
Looks to me like the valve on the thermostat housing your supposed to open when you fill the cooling system, but it is very hard to tell form the drawing.
Old Aug 9, 2006 | 07:22 PM
yeah but its not an open/shut style valve it stays installed as is.
Old Aug 9, 2006 | 07:23 PM
this particular system does not have a bleed screw.
Old Aug 9, 2006 | 07:40 PM
Can you post a pic of what it looks like on your car, that might help me get a better idea of what we are talking about?
Old Aug 9, 2006 | 07:44 PM
ill try to get one in the morning while at work with some light on the subject.
Old Aug 9, 2006 | 09:24 PM
illestrolla247's Avatar
my car overheats all the time and this thing is broke
brand new hg waterpump thermo everything and it still overheats
bump for answer
ik this thing has a shaft and a spring coiled around it if that helps
Old Aug 9, 2006 | 09:49 PM
pizzadude's Avatar
Default Re: (illestrolla247)
Does the cooling fan turn on? Could just be a bad cooling fan switch. They're like $25 bucks at Advanced.
Old Aug 9, 2006 | 10:01 PM
Gunmetal_B20_Hatch's Avatar
Default Re: what does this do exactly??? (NA_H22_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_H22_Ej &raquo;</TD></TR><TR><TD CLASS="quote">#24 looks like a fan switch, that cuts on the radiator fan when your thermostat opens </TD></TR></TABLE>
Actually #12 is the fan switch... sorry im no help, but I know its not the fan switch...
Old Aug 9, 2006 | 10:32 PM
sauceja's Avatar
Default Re: what does this do exactly??? (Gunmetal_B20_Hatch)
Actually #13 is the switch that tells the fan when to come on. I just replaced one on a B18C1 last night for a neighbor and voila fan came on no more overheating.
Old Aug 9, 2006 | 10:40 PM
EK k kay's Avatar
Default Re: what does this do exactly??? (sauceja)
I believe it has something to do with the 99-00 air injection system.
Old Aug 10, 2006 | 03:05 AM
NA_H22_Ej's Avatar
oh **** didn't look at it closely, prolly the bleeder valve to release air in your coolant system, air can cause ur motor to heat up cuz no water is gettin in until that airjack gets out...
Old Aug 10, 2006 | 09:52 AM
Default Re: (aallbbeerrtttttt)
did it have any effect on his vehicle?
Old Aug 10, 2006 | 09:54 AM
Default Re: (Teal93eg)
yes the fan comes on and still overheats...odd
Old Aug 10, 2006 | 09:58 AM
philosofy1's Avatar
#24 is probably t pipe that feeds into the heater core. not sure though.
but back to your overheating. IMO, dump the old stuff,change the thermo, and put new fluid in there, and make sure you burb the system. most likely you have air in your system.
Old Aug 10, 2006 | 10:07 AM
Default Re: (philosofy1)
dump what old stuff.....after it sat for 4 years it had nothing in it..so it has all new 50/50 mix of coolant/water.
im gonna try the thermo this weekend hopefully it fixes it. but i already know it opens and shuts b/c otherwise the fan would not kick on.
Old Aug 10, 2006 | 10:12 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22apwrdcivic &raquo;</TD></TR><TR><TD CLASS="quote">dump what old stuff.....after it sat for 4 years it had nothing in it..so it has all new 50/50 mix of coolant/water.
im gonna try the thermo this weekend hopefully it fixes it. but i already know it opens and shuts b/c otherwise the fan would not kick on.</TD></TR></TABLE>
sorry, i miss read it. i thought you said there was fluid in there even after 4 years. LOL!
yeah, change the thermo. though the fan is kicking on maybe the thermo isn't opening all the way that it should.
Old Aug 10, 2006 | 10:28 AM
djsire's Avatar
you have an air pocket!!!
let the car run with the cap off and let all the bubbles come out
Old Aug 10, 2006 | 04:11 PM
Default Re: what does this do exactly??? (djsire)
tried that already.
Old Aug 10, 2006 | 05:54 PM
JSPECSIR's Avatar
i believe that valve has a vacuum line that hooks to it to help keep air out of the cooling system, once the thermostat opens that valve shuts. some how it gets the air out without getting coolant out.
Old Aug 10, 2006 | 05:57 PM
cool well i need to try and find a diagram of how to hook those up....and to try and find a new one.
Old Aug 10, 2006 | 06:13 PM
Syndacate's Avatar
Uhhh
What did advance auto or autozone say this incredibly important small and probably cheap part costs?
You have the name of it.
And if you don't feel compfortable with that bring the ******* diagram.
Old Aug 10, 2006 | 07:13 PM
VTAKKK!!'s Avatar
looks like a thermo vacuum switch to me
