my setup
Old Aug 9, 2006 | 06:05 PM
tshuajzoo559's Avatar
Default my setup
LMK wat ya think i hit with my setup stock block....no ported head
civic hx
d16y5 vtec-e
skunk 2 cam shaft
str cam gear
eldelbrock performance x mani
aem v2 cold air
4-2-1 dc header
p28
full act clucth
jdm lsd tranny
good or bad setup....will it be atleast low 15s and high 14s
Old Aug 9, 2006 | 06:11 PM
Syndacate's Avatar
It's okay....my I/E/ECU civic could probably still take it :-P
It's not that great if you (and you have to) consider the fact it's an economy motor, you'll be lucky to see 100whp w/ that setup
FOR that engine though, that's a decent build...won't put you into the 14's...but it's a nic build...makes you faster than any other stock hx anyways O.o
Also, is the ECU tuned? Was it tuned after the cam gear and camshaft were added (same w/ the mani)?
Old Aug 9, 2006 | 06:16 PM
Default Re: (Syndacate)
wat about throwing a y8 head to it and then tuning the ECU
Old Aug 19, 2006 | 12:50 PM
any ideas??
mengy007
Jan 22, 2007 12:58 PM
mengy007
Jan 12, 2007 11:50 AM
dohdoh420
Jun 6, 2006 02:48 PM
boostincoupe
Mar 22, 2006 08:52 AM
Kolijian
May 13, 2002 09:12 AM
