aftermarket keyless entry question
so i got sick of having to use my key to unlock my car especially at night, cant find the hole,
so i went to best buy and bought a cheap clicker and decided that since i was able to do an engine swap and am pretty good with electrical work, that i could install it myself. well i got the thing to work for the most part except for the option to make the driver door unlock with click one of unlock key then all doors with second click. i looked in the repair manual for a wiring diagram and found some wires that are supposed to control the drivers side door solenoid but I've tried them all but no luck. so to sum this up i was wondering if anyone else has installed a key-less and knows which wire i should tap to make this work.
Thanks
MaXiMuS
so i went to best buy and bought a cheap clicker and decided that since i was able to do an engine swap and am pretty good with electrical work, that i could install it myself. well i got the thing to work for the most part except for the option to make the driver door unlock with click one of unlock key then all doors with second click. i looked in the repair manual for a wiring diagram and found some wires that are supposed to control the drivers side door solenoid but I've tried them all but no luck. so to sum this up i was wondering if anyone else has installed a key-less and knows which wire i should tap to make this work.Thanks
MaXiMuS
figures well i came to the conclusion that being able to just click the button and have all doors unlock is better then not having the clicker at all so im just gonna leave it like that
Thanks anyways
Thanks anyways
Unless there are two unlock wires, which on the Accords there isn't, you can't do progressive unlock. I actually work at a Best Buy doing installs just so you know. Cars that have factory progressive unlock, usually newer cars and a LOT of European cars seem to have it too, then there's nothing you can do. If you look at the instruction manual for the alarm, there should be a couple of pages on programming it, you can try enabling the progressive unlock feature and you might get lucky, but don't get your hopes up.
EsotericImage
Audio / Security / Video
Jan 22, 2013 11:46 AM
importdude2000
12
Jun 20, 2011 06:54 PM
PINKS
27
Mar 23, 2006 02:06 PM
boosted civic 2k6
Oct 7, 2005 10:55 PM
