Audio Security System
Just bought a 03 Accord, had a new batttery put in, the audio system reset itself. I have the original security code and serial number. But, does not work. I tried to redo the battery and start over. No luck. I live 2.5 hours from nearest dealership, trying to figure out solution--before I make the drive.
The stereo is 6 cd changer. The manual says you get 10 tries to put in correct code, otherwise the system has to be on for 1/2 hour, to retry. Then had the battery disconnected and them reconnected and then tried to imput code again...
any ideas???
thanks in advance---
any ideas???
It might be possible that the original owner had the 6 disc CD put in as an option and thats why the codes don't match. On those newer units you can push the 5 and 8 buttons and the faceplate will flash up the serial number. Then see if they match
ShankJDM
10
Jan 9, 2008 10:21 PM
smores
Audio / Security / Video
Jul 4, 2005 07:40 PM
