Oil Filter Swap Without Draining Oil?
Old Aug 9, 2006 | 01:32 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Oil Filter Swap Without Draining Oil?
I really wanna get rid of an oilder filter that Im running on my car but dont wanna be botherred with changing the oil that I changed 50 miles ago, dont even wanna lift the car off the ground.
Can I swap filters without draining the oil or will oil go everywhere. Does oil sit there behind the filter after the car is off?
Old Aug 9, 2006 | 01:38 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Oil Filter Swap Without Draining Oil? (PINKS)
The loss will be minimal unless you start it..
Just set a drain pan underneath and you will be fine..
Old Aug 9, 2006 | 02:12 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Oil Filter Swap Without Draining Oil? (88DXCRX)
No the oil is not backed up behind the filter. The filter, however, will always be filled with oil. So no matter what you do, some is gonna come pouring out when you remove it. You should definently re-check your oil level (and add more if necissary) after you swap filters & run the car for a moment...
Old Aug 9, 2006 | 02:19 PM
PINKS's Avatar
Default Re: Oil Filter Swap Without Draining Oil? (94eg!)
Alrighty I guess I'll try that, ive got a little above the top mark so it should be good.
Im lazy and just use the full 4liters
Thanks guys
holmesnmanny
Dec 10, 2009 03:14 AM
happynoodleboy
Feb 20, 2008 06:34 PM
Iomega01
Mar 25, 2006 09:07 AM
Sohc Driver
32
Jul 15, 2003 02:46 PM
dclub01
May 1, 2003 03:22 PM
