94 del sol S brake problems...
so im driving home right.... and i got off the freeway started breaking and then all of a suddon my break peddle like went to the floor and i wasnt really slowin down that much... i freaked... down shifter and pulled the e-brake and then the brakes started workin again. Then like 5 mins later... it happened again was braking and like the brake peddle went to the floor..... i have break fluid... so what could be the cause?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solrickCC »</TD></TR><TR><TD CLASS="quote">so im driving home right.... and i got off the freeway started breaking and then all of a suddon my break peddle like went to the floor and i wasnt really slowin down that much... i freaked... down shifter and pulled the e-brake and then the brakes started workin again. Then like 5 mins later... it happened again was braking and like the brake peddle went to the floor..... i have break fluid... so what could be the cause?</TD></TR></TABLE>
chances are you master cylinder is going out, time to replace it. also double check all brake lines and inspect your calipers. sometimes the seals in the caliper go bad as well and leak. but i'm going to lean more toward your m/c. quite easy to replace, have fun!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
Agreed, swap out both ur MC and ur SC (good to change 'em at the same time)
If the fluid reservoir on the master cylinder is not losing any fluid, then the MC has an internal seal leak and must be replaced. If you are losing fluid, there is an external MC leak (between the MC and the booster) or a leak elsewhere in the system (lines, calipers, etc.) and you'll have to look for signs of fluid leakage.
Neptronix
21
Mar 26, 2008 09:35 AM
