Turbo CRX project question
I found a turbo Tsi Talon. I will be doing a "junkyard" turbo and using uberdata, I have the manifold off a d15z1 ... the DSM has the td04 turbo, blow off, and intercooler...
Should I be taking anything else off the Talon? It is untouched right now... would I need the injectors or fuel pump?
TIA..
(I did search this...WAY too much info to filter to get the answer)
TIA..
Thanks for all the help guys...
Dirty... I will PM you if I end up NOT needing the injectors...
One more question...
The engine is a d16z6... I have both a p28 ECU and a PM6...
IYO should I use Uberdata (p28 OBD1) or TurboEdit (PM6 OBD0)..??
Either is an option... I just want experience to guide my way...
adrenal
May 24, 2004 01:42 PM
