CA smog check...
I have a vx model hatch with a dx motor in it. does anyone know if i will be able to pass the smog test with it...assuming everythings working correctly and the engine check isnt' on.
the swap is legal but we can't tell you whether you will pass or not since that depends on how your engine is running. if the car is running fine, then it should pass smog.
the previous owner of my car swapped a hx into a ex and didn't pass smog the first time. it was running rich, but passed the second time.
