car wont start, pump not priming.
Old Aug 9, 2006 | 11:12 AM
Turbo_y8's Avatar
Default car wont start, pump not priming.
98 ex. has had no starting problems till now. Went to start it, pump isnt priming, wont crank, tried jumping it, nothing. checked fuses. any ideas?
Old Aug 9, 2006 | 11:15 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: car wont start, pump not priming. (Turbo_y8)
bad starter? ground wire by the starter is corroded?
Old Aug 9, 2006 | 11:19 AM
kaj's Avatar
kaj
are you getting power at all? if your pump isn't priming then it's not just your starter, obviously. you have a different, electrical problem. check the ignition pieces in your steering column, the ecu, etc. does the car have power everywhere else? radio, etc?
Old Aug 9, 2006 | 11:24 AM
CanuckCRX's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 &raquo;</TD></TR><TR><TD CLASS="quote">98 ex. has had no starting problems till now. Went to start it, pump isnt priming, wont crank, tried jumping it, nothing. checked fuses. any ideas?</TD></TR></TABLE>
Check the ECU for codes. If you have Code 0 (CEL remiains LIT) then your ECU needs repair or replaced. There is a capacitor on the board in the ECU which is notorious for leaking, and it is the one that drives the main relay/fuel pump. WHen this cap goes, you get no fuel and no spark. It is a 220uF 35V cap near the ECU plugs.
Old Aug 9, 2006 | 11:26 AM
Jack8788's Avatar
Sounds like the main relay for the fuel pump isnt working. try replacing it
Old Aug 9, 2006 | 11:27 AM
Turbo_y8's Avatar
Default Re: car wont start, pump not priming. (Jack8788)
when i try starting no lights on the dash light up. Then i ran a ground from the neg batt. post to the head kinda cranks. Then the line i used started smoking?
Old Aug 9, 2006 | 11:33 AM
Dwight Schrute's Avatar
listen to the guy above you. its probably your man relay. pull it out and pop of the cap and look at the solder pads. if there are cracks , just blob a small amount of solder on and you're good to go.
Old Aug 9, 2006 | 11:40 AM
Turbo_y8's Avatar
Default Re: car wont start, pump not priming. (drewthomas14)
Nope, got it running, there was a insect on the front ground cable, from the rad. support to the head area. Peeled it off and started up. started it 10 times no probs now.
Old Aug 9, 2006 | 11:47 AM
random.
Old Aug 9, 2006 | 11:48 AM
Turbo_y8's Avatar
very. and my car is getting tuned tomorrow so it was like SOB and last time it was going ot be tuned the night before i threw a rod bad luck i guess
Old Aug 9, 2006 | 06:23 PM
kaj's Avatar
kaj
that is the strangest problem/solution i've ever read.
Old Aug 9, 2006 | 06:36 PM
98-00's Avatar
Default Re: (kaj)
Im going to have to spray OFF on my grounds from now on.
Old Aug 9, 2006 | 06:38 PM
cute little bastard
OOOO Who said something about a ground wire? ME bitches
If it was the relay his cluster lights would still light up
Old Aug 9, 2006 | 08:20 PM
kaj's Avatar
kaj
i had a bad ground on my thermostat housing. it LOOKED fine, but the car would just DIE on me while driving. all power.. gone. then start back up. weird.
when i went to tighten the bolt, it broke off. corroded. ha! moved the ground to a new location = fixed.
Old Aug 9, 2006 | 08:44 PM
Turbo_y8's Avatar
Default Re: (kaj)
and it was wierd because i checked the ground on the thermostat and got nohting would look around and leaning on the rad. support id hear the fuel system prime, so i would go to start it, it would turn over as if the battery were dead band then the rad. fan would turn on, turn the key off, and then nothing. it was pretty weird, but now im going to clean up all my grounds.
DaxTarbet
Oct 19, 2017 04:20 PM
KCVBALL17
19
Oct 21, 2015 11:25 AM
kaz norvaisas
Jun 30, 2015 03:41 AM
berdo94da
Jun 27, 2008 11:47 PM
taboo948
May 19, 2008 07:26 AM
