Some questions on brake pad change
Old Apr 24, 2002 | 03:55 PM
onyx00's Avatar
Default Some questions on brake pad change
1.) As a substitute for Molykote, I should use brake disc lubricant, right?
2.) How much Molykote/lubricant should I use on each side of the shim? Thin layer, thick layer?
3.) Just Molykote/lubricant on the shims on both sides, no where else on the pads, or retainers in the calipers?
4.) Any other tips for installing new pads (these are OEM pads) ?
Old Apr 24, 2002 | 04:05 PM
yoshi234's Avatar
I shoot brides
Default Re: Some questions on brake pad change (onyx00)
1) j00 can, but I use anti-seize
2) very thin layer between the shim and backing plate. if j00 put thick layer on, it'll 00ze out and make a mess
3) double check everything once you're done
jdadams12
Aug 31, 2010 12:50 PM
Lude454
Jul 17, 2005 09:59 AM
DaKINE-Ek
May 22, 2004 02:40 PM
FitCRX
Jul 6, 2003 06:14 AM
rus
Oct 5, 2002 07:39 PM
