Headers
Old Aug 9, 2006 | 04:42 AM
bbhockey19's Avatar
Default Headers
I just Installed Greddy Headers on my Sohc Vtec civic... everything is on properly my dad is a machanic so he ozziously know what he is doin.. but it sounds like there is air coming out under the car...which can mean loss of power and gas mileage.. Let me know whats wrong
Old Aug 9, 2006 | 05:47 AM
bbhockey19's Avatar
Default Re: Headers (bbhockey19)
Any Suggestion's what the problem is.. it sounds like air is leaking out of them
Old Aug 9, 2006 | 06:11 AM
Everyones Hero's Avatar
See if all of your flanges are lined up and tight and make sure there are no cracks in the header.
Did you forget to put a gasket between the header & cat?
Old Aug 9, 2006 | 06:31 AM
bbhockey19's Avatar
Default Re: Headers (Everyones Hero)
I put everything on.. and everything is properly tighten... and the header wasn't cracked because they were brand new
Old Aug 9, 2006 | 06:41 AM
Syndacate's Avatar
well you obviously have a leak O.o
Old Aug 9, 2006 | 06:42 AM
sicky's Avatar
grammer nawzi
First, it's a header, not headers. Secondly, could be an exhaust leak from your piping, or it could be from a lack of properly tightened bolts on the header. I am assuming that you re-used some gasket that was cracked. Just take off what you put on recently and you will find the culprit. Finally, hit spell check for ****'s sake.
In case you were wondering, spell check has the "ABC/Check Mark" picture.
Ninja edit: Don't tell me you're in college? Wow, just wow.
Old Aug 9, 2006 | 07:37 AM
bbhockey19's Avatar
i put new gaskets on it when i changed it..
Old Aug 9, 2006 | 09:17 AM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbhockey19 &raquo;</TD></TR><TR><TD CLASS="quote">the header wasn't cracked because they were brand new</TD></TR></TABLE>
that's a bad assumption to make...
Old Aug 10, 2006 | 04:56 AM
bbhockey19's Avatar
my car just sounds different with them on.. at low rpms sound like there is a leak in my exhuast but that can't happen because it is a month old and also it was installed by a mechanic
Old Aug 10, 2006 | 05:18 AM
Sly_Samba's Avatar
HTBATRACER
Default Re: (bbhockey19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbhockey19 &raquo;</TD></TR><TR><TD CLASS="quote"> sound like there is a leak in my exhaust but that can't happen because it is a month old and also it was installed by a mechanic </TD></TR></TABLE>
Don't make such assumptions.
Old Aug 10, 2006 | 05:23 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbhockey19 &raquo;</TD></TR><TR><TD CLASS="quote">I just Installed Greddy Headers on my Sohc Vtec civic... everything is on properly my dad is a machanic so he ozziously know what he is doin.. but it sounds like there is air coming out under the car...which can mean loss of power and gas mileage.. Let me know whats wrong</TD></TR></TABLE>
i don't understand, if your dad is a mechanic, then why not ask him?
i would check you bolts where it meets the cat. or did you think that maybe that's how that brand of header sounds.
Old Aug 10, 2006 | 06:05 AM
DelSolMarine's Avatar
Default Re: Headers (philosofy1)
put the old gasket on there... it worked before mayb the new gasket on there is jacked up kinda hard to help u out when u have no pics or no sound clips
sliksivik
Sep 24, 2007 06:00 PM
jered247
Honda Civic (2001 - 2005)
15
May 13, 2006 04:13 AM
hakkoo
Feb 24, 2006 10:42 AM
CrAzyGsR101
Oct 22, 2003 10:16 PM
