so i bought an LS w/ a b16...
Old Aug 9, 2006 | 04:30 AM
itz_nij's Avatar
Default so i bought an LS w/ a b16...
so i bought an LS w/ a jdm b16 and it was driving fine until i lauched the car the other day... then i noticed a CEL and i pulled over and shut it down. cranked it back up no cel and started driving home then i noticed... NO VTEC!!! vtec wont engage anymore.. but it drives fine, i dont get what the hell happened
checked the CEL codes and this is what i got..
3 MAP - manifold absolute pressure sensor
20 Electrical load detector
22 VTEC pressure valve
41 Primary oxygen sensor heater
can i please get everybody opinion on this. i've read up on it and heard it could be oil pressure, might need to change my oil or oil pump or even recheck the wiring for my vtec. might even have to open up the head and clean everything up or replace my seals. i dont know.. has anyone came across this? i mean the vtec used to work so it cant be the wiring right?
Old Aug 9, 2006 | 04:32 AM
Danziver's Avatar
Default Re: so i bought an LS w/ a b16... (itz_nij)
I would check the oil and wiring first.
Old Aug 9, 2006 | 06:12 AM
PLAGUED_DB7's Avatar
Default Re: so i bought an LS w/ a b16... (Danziver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danziver &raquo;</TD></TR><TR><TD CLASS="quote">I would check the oil and wiring first.</TD></TR></TABLE>
Old Aug 9, 2006 | 06:27 PM
LDS's Avatar
LDS
Make sure your green plug to the right of the distributor is pluged in. if it is then check il and stuff. does the car have a VAFC in it? or maybe it had one and when they uninstalled it the didnt reattach the oil pressure switch for Vtec.
Old Aug 9, 2006 | 06:59 PM
itz_nij's Avatar
Default Re: (LDS)
i dont even know where the oil pressure sensor is. im going down to the car right now to check
Old Aug 9, 2006 | 11:32 PM
watsvtecEK's Avatar
Default Re: (itz_nij)
b16 no vtec sounds fun. bump
Old Aug 10, 2006 | 07:10 AM
itz_nij's Avatar
Default Re: (D 2da A9)
its the greatest thing in the world, no torque, no power, no vtec. YES!
Old Aug 10, 2006 | 07:11 AM
itz_nij's Avatar
anyways i checked the wiring, everything seems fine. i noticed that on the green clip by the dizzy the copper on the wires were coming out and touching each other. that could be a problem also
Old Aug 10, 2006 | 07:28 AM
VTECth1s's Avatar
sucks ....all those codes from just one launch? how hard and how far did you launch?
Old Aug 10, 2006 | 11:59 AM
itz_nij's Avatar
Default Re: so i bought an LS w/ a b16... (egg6vtak)
not that hard just a speedy get away, i came down to this. i think the vtec solenoid is out. its okay, i'll see wussup..putting a gsr in it soon
how much is a jdm b16a obd1 with integra type r cams w/ lsd tranny worth? 60k on the whole swap
Old Aug 10, 2006 | 12:33 PM
VTECth1s's Avatar
even with a launch like that...your motor must be sensitive, did it throw any codes prior to your launch?..a swap prolly id say between 3-4g's...is it w or w/o axles, shift linkage, ecu, mounts..etc? or jus the swap ?
Old Aug 11, 2006 | 11:48 AM
itz_nij's Avatar
the whole swap, everything you need to put it into a car. 3-4gs is too much, i would let it go for 2gs
thewrai6th
May 24, 2016 03:15 PM
calhoun
Nov 2, 2006 05:49 PM
mister2racer
Jun 26, 2005 07:13 PM
-Whitey-
12
Feb 4, 2003 01:24 PM
ysrhatch
Oct 17, 2001 11:41 AM
