90 Si/D16A6 removing tranny bolts (engine and mounts)
Old Aug 8, 2006 | 10:21 PM
( o )( o )'s Avatar
Default 90 Si/D16A6 removing tranny bolts (engine and mounts)
ok i have loosened 5 tranny-to-engine bolts...i can't see any more...are there more?
next will be the mounts, which my haynes manual has an absolutely non-applicable illustration...
I"ll post pics and maybe you guys can suggest which bolts, and in which order should I remove the mounts...thanks!
here's what i got:
front
passenger
rear1
rear2
Old Aug 8, 2006 | 10:22 PM
( o )( o )'s Avatar
Default Re: 90 Si/D16A6 removing tranny bolts (( o )( o ))
i'm thinking that the big 3 main bolts that go through the mounts are the ones i want...but then the mounts might be in the way when lowering the tranny on the tranny jack.....
Old Aug 9, 2006 | 07:08 AM
( o )( o )'s Avatar
morning bump
Old Aug 9, 2006 | 07:12 AM
janz3n's Avatar
is this just a progress thread or are you asking a question.. cuz if your asking aquestion then the reason why no one is answering it is cuz there isnt one.
Old Aug 9, 2006 | 07:42 AM
white90crxhf's Avatar
Default Re: 90 Si/D16A6 removing tranny bolts (janz3n)
remove all the bolts on the mounts. except the engine mount
did you remove your exhaust & the flywheel shield?
Old Aug 9, 2006 | 09:52 AM
( o )( o )'s Avatar
Default Re: 90 Si/D16A6 removing tranny bolts (white90crxhf)
ah yes the tranny shield....it was late last night - i'll revisit when i get home from work.
Old Aug 9, 2006 | 10:31 AM
Tyson's Avatar
dont forget the starter. you have to remove it completely.
Old Aug 9, 2006 | 02:24 PM
crAppAchic0's Avatar
Autozone has repair manuals available online-
http://www.autozone.com/servle...2.jsp
here's the tranny pics-
http://www.autozone.com/images...1.gif
That should be plenty....
Old Aug 10, 2006 | 08:00 AM
( o )( o )'s Avatar
Default Re: 90 Si/D16A6 removing tranny bolts (crAppAchic0)
thanks guys
i got the tranny and clutch out last night. OMG the clutch was bare metal and has grooved rings into the pressure plate LOL
Old Aug 10, 2006 | 08:02 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ( o )( o ) &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys
Hahaha...ya....they will do that! I got a nice burnt clutch that we took out of a 208whp B20 Vtec, the clutch was down to bare metal, which had heat/stress factures all over it. It was probably hours away from shatering.
a1320honda
Jan 27, 2012 02:08 AM
p2pwn
Jan 16, 2009 07:56 AM
gsxr1k05
Sep 24, 2006 07:52 PM
lavo81
Feb 13, 2005 03:46 PM
RED_October94LS
Mar 23, 2004 03:58 PM
