3 ring cam seal
Old Aug 8, 2006 | 09:31 PM
TSX TEX's Avatar
Default 3 ring cam seal
I ordered this from JHPUSA for my current project. Anyone out there use one yet? After seeing it n person I'm kinda iffy about using it. The rings though there are three they are hella thin.(I posted in cosmetic/apperance because of the high traffic)
Old Aug 8, 2006 | 10:01 PM
Mr. Samurai's Avatar
Default Re: 3 ring cam seal (iGntSegRa)
i doubt is gonna leak, bdl uses a 2 gasket seal and it works. 3 rings is kinda overkill. I used an oem cam seal and they've leaked on me before so I just used a bead of high temp silicone around an oem one and so far so good. If you're worried about it leaking just put a bead of silicone around it.
Old Aug 8, 2006 | 10:11 PM
swoyEKr.'s Avatar
You'll be straight.. i've got the bdl 2 seal one and it works fine.
Old Aug 8, 2006 | 10:31 PM
TSX TEX's Avatar
Default Re: (swoyEKr.)
good info
Old Aug 8, 2006 | 11:30 PM
dunkd's Avatar
use some hondabond as well.
Old Aug 8, 2006 | 11:53 PM
revvin9k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swoyEKr. &raquo;</TD></TR><TR><TD CLASS="quote">You'll be straight.. i've got the bdl 2 seal one and it works fine. </TD></TR></TABLE>
He was asking about the three ring, not the double.
Old Aug 9, 2006 | 01:07 PM
dunkd's Avatar
Default Re: 3 ring cam seal (revvin9k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revvin9k &raquo;</TD></TR><TR><TD CLASS="quote">He was asking about the three ring, not the double.</TD></TR></TABLE>
the 3ring is supposed to be better than the 2ring. Honda actually started using 3ring cam seals in 96 I think. 94 and 95's only have 2ring cam seals.
jonyi27
Jan 27, 2013 07:29 AM
Dxs
Jul 1, 2008 11:14 PM
Wayne_Curr
Jun 13, 2007 02:10 PM
R1_Owner
Oct 3, 2006 05:06 PM
sinister357
Aug 29, 2005 09:47 PM
