whats the best possible tranny
im a new user, and i finally just got my very own itr, i bought it off a friend who really didnt know how to drive, when i got it it had a slight chirp/grind going into 3rd, i know the best thing would have been to get it fixed right away, but tuning on a budget plus the rediculous cost of living in cali, i couldnt. now, theres no churp just grinding after 5000 rpm, becuase everyone wants to try and run with an itr i admit i made the problem a whole lot worse. ne who i had taken it to get a qoute at a shop near by, this guy suggested swapping it out for a b16, but keep my diffs from the tranny i have nowto keep it lsd, hes says the b16 would be would open my car up so much more. i m looking for some knowledgeable feedback and am open to any and all suggestions. thanks
Your tranny shop doesn't know much about Honda transmissions then.
The recent 16A/USDM/JDM 96spec transmissions all share the same gear ratios.
Your best bet would be to either get a final drive, either in OEM 4.785 variety, ATS 4.9, MFactory/Infinitude 4.9 and/or close/cross gears....
Otherwise, just replace the syncros + bearings + hubs.... I just like the peace of mind, while it's possible that the syncros will only require replacing...
pulled two Bseries transmissions in the last month... wasn't exactly fun
F that, keep your tranny and do a tranny fluid flush, see if that helps first. If not you can pull the tranny and replace the scyncros (sp?) for around $230. As for what the best tranny is there are many options and gearing you can explore but it really depends on your goals for the car i.e. auto x, road race, daily driver, drag? Each of thes different types of racing have very different needs when it comes to the gearing.
-Paul
-Paul
hey thanks man, another ? for you, i just had my car checked out cus i my oil light came on right after i hit vtec. the thing is i just got an oil change barely a month ago, so i took it to a mechanic, he tore it apart and said there were no leaks, cracks , ventage, nothing , he said everything is perfect that maybe they just shorted me and the oil change, but now a little over 2 weeks i check my oil again, the things damn near empty, nohting in my plugs or driveway,...ne ideas?????
is the back side of the car black? you had someone else do your oil change....so you sure they put oil in it? ahh...the worries of someone else working on my car.
if the oil light come on...its usally to late. thats why they call it a idiot light. your an idiot for letting it come on.
no man no black residue nothing in the driveway or in my plugs,, the thing is i too it to a mechanic and he said everything was beautiful.... so now i dont know what the deal is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">This thread gave me a headache
must have...i know it gave me a headache. His problem was caused b/c everybody wants to run against a type r
tyte!
</TD></TR></TABLE>must have...i know it gave me a headache. His problem was caused b/c everybody wants to run against a type r
tyte!
99SlammedCivic
Sep 18, 2005 01:43 PM
ebp 99 si
Apr 17, 2003 07:12 PM
Drinker
