Wiring Factory Fogs
Has anyone here wired their factory fogs to go on with the low beams? i have a set with the wiring harness, but i'd like to wire them to the low beams. I know that i need to run seperate power from the battery to the lights, but where would i connect the fogs to the low beams?
Thanks
Scary
Thanks
Scary
you would connect them to the vehicle harness that is on the drivers side by the head light assembly it is attached with blue tape...remove the tape and plug in the vechicle harness to the fog light harness..its simple then just ground the wire. I just did mine an hour ago.
92EG8
Aug 7, 2007 02:50 PM
pmendoza
Mar 31, 2006 04:21 AM
Sean @ ESG
Feb 23, 2006 01:30 PM
