Couple Swap Wiring Questions
Old Aug 8, 2006 | 05:22 PM
neonphire8604's Avatar
Default Couple Swap Wiring Questions
I can't figure out a few last clips/plugs, putting a ZC in my 91 Si. First one comes out of the engine harness right by the O2 sensor, it's a round plug, two wires going to it, green\white and red\white. Second, the two wires underneath the intake manifold, they have a rubber boot and go to a sensor with 2 studs coming out, which wire goes to which side? Thanks, and I did search also
Old Aug 8, 2006 | 05:44 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Couple Swap Wiring Questions (neonphire8604)
The rubber boot/two wires are for the fan switch..
The order does not matter as it is just a switch..
Just plug them in..
The other is probably the coolant temperature sensor..
should plug into the head under the distributor toward the front..
Old Aug 8, 2006 | 05:58 PM
Thanks for the help
Old Aug 8, 2006 | 06:01 PM
jlicrx's Avatar
Default Re: Couple Swap Wiring Questions (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">The rubber boot/two wires are for the fan switch..
Just plug them in..
should plug into the head under the distributor toward the front.. </TD></TR></TABLE>
Old Aug 8, 2006 | 06:38 PM
88DXCRX's Avatar
Default Re: Couple Swap Wiring Questions (jlicrx)
Should be the small round plug in that group of wires...
And plug somewhere around here:
The other red/green plug that comes to mind is intake air temp sensor....
I have never dealt with the ZC but it is all about the same...
jlicrx=ZC Guru
Old Aug 8, 2006 | 08:00 PM
Doh!'s Avatar
The one plug that doesnt get used on the ZC is in the cluster of wires that goes to the fan switch and alternator, correct? It's two wires I believe.. ?
rustanghunter
Jun 14, 2010 06:58 AM
tibss
Jan 31, 2008 11:28 PM
Sirfallsalot243
Dec 22, 2006 08:37 PM
regime
Jun 1, 2004 02:10 PM
b16hybridsol
Nov 11, 2003 04:59 PM
