eg rear discs on ek?b
can i use the rear discs off a 94 ex/si and put them on a ek hatch? i know the lower control arm is different but is the trailing arm or anything else different? thanks.
Trailing arms are identical and will bolt up...but im not sure which ebrake cables you would use, i would think youd need ones from an EG or a DC.
i did and search and someone said " some " of the 92-95 ex/si rear discs work on ek's but didnt say which ones. i imagine the trailing arms would all be the same. i have the e-brake cables off eg si also.
blk007
Suspension & Brakes
May 10, 2006 09:20 AM
endlesswinterco
12
Nov 7, 2003 05:43 AM
