Is my Brake Master Cylinder still good???
Here is my issue:
There is a leak where my brake master cylinder is attached to the brake booster. My brake still works and all, but it looses a lot of fluid. I was wondering if its just a seal between the master cylinder and brake booster. There were a few times my brake pedal went down kind of low, but most of the times it brakes just fine.
I went a bought a new master cylinder anyways, and I notice there is a rubber seal that sits between the booster and cylinder. Im just wondering if anyone knows if I should change the master cylinder, or I only need to change the seals. Thanks
There is a seal inbetween the booster and master cylinder. Try replacing that first. If it still leaks, you need a new master cylinder.
AWD: Jeff
Suspension & Brakes
Jul 3, 2010 06:47 AM
mattbatson
Oct 23, 2008 07:30 PM
