having problems with the brakes
Old Aug 8, 2006 | 03:18 PM
vince37's Avatar
Default having problems with the brakes
Well start I have try to bleed the brakes but with no success. help
Old Aug 8, 2006 | 04:27 PM
Froth's Avatar
Default Re: having problems with the brakes (vince37)
1- Have someone get in the car and pump up the brakes, 5-10 GOOD pumps. Have them HOLD the pedal in.
2- Crack open the brake fluid bleeder and out comes Air/Fluid.
3- Tighten the bleeder back down, Repeat one more time. (you may have to add fluid while bleeding)
Do this at every wheel, Add new fluid when you're done.
Old Aug 8, 2006 | 06:13 PM
SL!M's Avatar
starting with the farthest from the master cylinder, so the passenger rear.
Old Aug 8, 2006 | 06:16 PM
d16vteceg's Avatar
Default Re: having problems with the brakes (Froth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Froth &raquo;</TD></TR><TR><TD CLASS="quote">1- Have someone get in the car and pump up the brakes, 5-10 GOOD pumps. Have them HOLD the pedal in.
Do this at every wheel, Add new fluid when you're done.</TD></TR></TABLE>
This is correct, just make sure that you tighten the bleeder back down after you get a steady flow of brake fluid and there is absolutely no air left in the line.
chowderhead
Sep 11, 2017 03:24 PM
Jose-aka-Pedro
May 18, 2006 03:25 PM
detaude
Honda Motorcycles
May 18, 2005 03:46 PM
Jordan_4WS
Jan 20, 2003 02:10 PM
