stage 1 to stage 2
Old Aug 8, 2006 | 02:12 PM
DARKTEG_'s Avatar
Default stage 1 to stage 2
will i notice any difference going from stage 1 crower cams to stage 2 crower cams in my b18b?
Old Aug 8, 2006 | 04:47 PM
notstock93's Avatar
Default Re: stage 1 to stage 2 (gonk_1)
Well...thats kind of the whole point, isnt it?
You would notive a bigger difference if you tune them, though. Cams NEED to be tuned to make them worth it.
Old Aug 9, 2006 | 07:11 AM
b18sihatch's Avatar
stage 2 has a larger profile so yes in return the larger lift/duration will benifit your motor, but like the other poster said, tuning is key to seeing the most gains out of the upgrade
Old Aug 9, 2006 | 12:15 PM
DARKTEG_'s Avatar
Default Re: stage 1 to stage 2 (b18sihatch)
i have it tuned at -4 exhaust and - 1 intake side
this is what i have in it right now...
Act stage 4 clutch, pressure plate, and release bearing
AEM Cold air intake
AEM fuel rail
AEM tru time pulleys
B&M fuel pressure regulater, with gauge
Crower stage 1 cams
DC Sports 4 2 1 one piece header
Golden eagle adjustable cam gears
GSR obd2 injectors
Hondata intake gasket
lightweight flywheel
Skunk 2 intake manifold
Old Aug 9, 2006 | 12:30 PM
notstock93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gonk_1 &raquo;</TD></TR><TR><TD CLASS="quote">i have it tuned at -4 exhaust and - 1 intake side </TD></TR></TABLE>
No, you have it SET at those degree's, you need a Hondata, Crome, Uberdata or something like that to tune the actual air/fuel ratios and such. That is where you will be getting the most horsepower, not cam gears (although they help)
Old Aug 9, 2006 | 01:28 PM
DARKTEG_'s Avatar
Default Re: stage 1 to stage 2 (notstock93)
ya, i'll probably wait till the spring to do that though
Old Aug 9, 2006 | 02:00 PM
notstock93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gonk_1 &raquo;</TD></TR><TR><TD CLASS="quote">ya, i'll probably wait till the spring to do that though</TD></TR></TABLE>
My advice is to save yourself a LOT of headaches and aggravation and put in stage two cams when you have the time and money built up to have them street tuned at the same time. It will cost more, but it will be worth it. In fact, when I got my stage two D16 cam tuned, it was like driving a totally different car.
The powerband will widen
Peak horse can/will go up
Throttle response will improve.
Gas mileage can increase.
There are tons of reasons to do this right, i just don't want to see you have to have any extra problems.
Old Aug 12, 2006 | 07:37 AM
ge_itr's Avatar
Default B18C5
similar setup
B18C5
hondata s100
skunk 2 stage 3 camshaft w/ complete skunk valve train
aem adj. cam gears
rc 440 cc injecter
unothodox crank pulley
i going to get my car tune next week. seems like there alot of forums about stage 2 but i need info on stage 3. is it going to be hard to tune my rough idle? what gains will i get after my tune? what WHP will i get.
"thinking about higher compression pistons
kornerk12
Feb 13, 2007 08:03 AM
DARKTEG_
Aug 8, 2006 02:14 PM
SymphonyX
Apr 28, 2003 08:39 PM
