NEED HELP ON SOHC
Old Aug 8, 2006 | 02:02 PM
tshuajzoo559's Avatar
Default NEED HELP ON SOHC
ok...heres the deal...yesterday i finally put on the pigtail changing it to a OBD1 from a OBD 2...using a chip P06....with intake header and mani....the problem is that when i rev to 3200 its like bogging and lag when you punch it....cant even feel like its pickin up.....but when it hit 7200 RPM....it pulls like a LS-V.....wtf??? need SOHC expert or anything will do....thanks
Old Aug 8, 2006 | 02:05 PM
oldskoolkid's Avatar
Default Re: NEED HELP ON SOHC (tshuajzoo559)
try a different ECU and if not that a new distributor
Old Aug 8, 2006 | 04:05 PM
Default Re: NEED HELP ON SOHC (EgSick6)
will a 94 distributor work on a 96??....
Old Aug 8, 2006 | 04:10 PM
-DesTiNy-'s Avatar
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tshuajzoo559 &raquo;</TD></TR><TR><TD CLASS="quote">will a 94 distributor work on a 96??....</TD></TR></TABLE>
it wont work.. it will bogg if you do that trust me it dont fit right
Old Aug 8, 2006 | 05:34 PM
Default Re: NEED HELP ON SOHC (-DesTiNy-)
if dont change the dist....should i try the P28
Old Aug 8, 2006 | 09:00 PM
95civicSirCoupe's Avatar
p28 ecu
Old Aug 19, 2006 | 12:49 PM
still need help
Old Aug 19, 2006 | 01:43 PM
-JSpecEk*9-'s Avatar
Default Re: (tshuajzoo559)
how are you hittn 7200rpm on a sohc?
Old Aug 19, 2006 | 01:45 PM
NJcoupe's Avatar
Default Re: (JDMEK-9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMEK-9 &raquo;</TD></TR><TR><TD CLASS="quote">how are you hittn 7200rpm on a sohc?</TD></TR></TABLE>
What does a stock D16Z6 rev to?
What motor are you running?
Old Aug 19, 2006 | 03:00 PM
ci_v_ic's Avatar
Default Re: (dxcoupe.)
could be the wrong harness. was it obd2a or b?? depending on what company you ordered from the obd2a to obd1 is different from the obd2b to obd1 harness so you might wanna follow up on that.
xxh3iiraz0rxx
Jul 2, 2007 06:53 PM
Honda_SiR-G
Apr 17, 2007 08:16 AM
civic89si666
Mar 22, 2006 01:41 PM
PhatHatch89
Jul 6, 2003 07:37 PM
