just did swap, i got a question
Old Aug 8, 2006 | 01:45 PM
MR EK's Avatar
Default just did swap, i got a question
i just did a swap in my 96 hatch, i went from the dx motor(d16y7) to the ex motor(d16y8 fully built)
i wanted to know how i can get the VTEC to work......i see the 2 plugs on my head but what do i need to hook it up to my ecu......what are the pieces called?
thanks guys
Old Aug 8, 2006 | 01:52 PM
CH2iS*'s Avatar
Default Re: just did swap, i got a question (SBFSLEEPY)
https://honda-tech.com/zerothread/1171263
sticky at the top for you to find easier. please search.
Old Aug 8, 2006 | 02:09 PM
MR EK's Avatar
sorry bro i did search but was still confused.....i know where to put them but i wanna know what i should ask for when i go to the junkyard.......basicly what is it called that i need
Thanks
Old Aug 8, 2006 | 03:56 PM
Slopoke's Avatar
Default Re: (SBFSLEEPY)
I assume you are using a vtec ecu also, right?
All you need is some wire the proper connectors on one end and ecu pins on the other.
Old Aug 8, 2006 | 04:25 PM
pennies_hatchie's Avatar
Default Re: (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">I assume you are using a vtec ecu also, right?
All you need is some wire the proper connectors on one end and ecu pins on the other.</TD></TR></TABLE>
or if you cant do that or you want a cleaner look, then just get a obd2a civic ex wire harness.
EK9Undisputed
Aug 11, 2008 12:26 PM
EK9Undisputed
15
Aug 10, 2008 08:35 PM
rharris84
Jan 24, 2007 10:23 AM
jpizzi
11
Aug 29, 2006 12:56 PM
jdmcivichatch96
Oct 16, 2003 10:20 AM
