H22-H24 using F23 crank- are my calcs correct?
My first time running calculations like this, so if I am wrong at least I tried.
H22A closed deck block bored to 89MM
F23 crank(97MM stroke) with H22 main bearings
Custom rods- length-5.551 Width- .780 Pin bore- .8649-.8654 BE- 1.890 (F23 rod but strong materials) using F23 bearings
Custom pistons- 89MM 11:1CR with a compression height of 1.179
If my calcs came out correctly(which may not have) this would retain the same deck clearance of a stock H22(.004).
Info gathered for the calcs came from prelude forum FAQ on H\F motor specs.
jdm_rb20
17
Mar 6, 2013 07:43 PM
