Opera S2000-ish setup questions
Old Aug 8, 2006 | 10:54 AM
Briman2021's Avatar
Default Opera S2000-ish setup questions
For those that don't know what I am talking about, this is what I am thinking of doing to my car.
http://www.s2ki.com/forums/ind...26013
I was wondering what steps he took after drilling the holes, because I know it is more complex than taking a holesaw to your car. Did he just use a chamfer bit and chamfer the holes, or did he actually flare them out with some sort of a die??
Thanks
Old Aug 8, 2006 | 01:44 PM
Briman2021's Avatar
Default Re: Opera S2000-ish setup questions (Briman2021)
anyone??
Old Aug 8, 2006 | 03:28 PM
_BEN_'s Avatar
You want to swiss cheese your car?
Yeah some of those holes look like they have been Dimpled.
The tool you will need is either called a flare or dimple die.
They also use them for counter sinking holes for flush rivets.
http://vansantent.com/sheet_me...s.htm
If you ever get to look up close at an airplane you will see that the they drill holes and flare them to save weight and retain structural integrity at the same time.
Old Aug 9, 2006 | 11:44 AM
Briman2021's Avatar
Default Re: Opera S2000-ish setup questions (_BEN_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">You want to swiss cheese your car?
How would I flare a hole with one of those if the part couldn't be removed from my car, or if it wouldn't fit on a "bench press" like for instance, the inside of my door.
Old Aug 10, 2006 | 10:55 AM
_BEN_'s Avatar
Allot of those parts were fabricated off of the car. Then welded to it.
You can also use the stamp like you would a bushing press.
Here is a photo to help you visualize.
http://www.thepartsbin.com/car...1.jpg
Old Aug 10, 2006 | 01:53 PM
Briman2021's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">Allot of those parts were fabricated off of the car. Then welded to it.
http://www.thepartsbin.com/car...1.jpg</TD></TR></TABLE>
Well, I figured a bunch of the parts were done off of the car, but I can't imagine how some of them would be, like the inner fender which is part of the unibody. But that tool in the picture you posted makes a lot of sense.
Where would I get something like that??
Also, for past of the car that I couldn't get to the backside of, could I hammer on the back of one of those dies to get the hole to flare out??
Jasper_db1
Honda Motorcycles
17
Sep 23, 2010 08:32 AM
Junkyard2000
Audio / Security / Video
Jun 19, 2005 08:25 PM
MooreBoost
Welding / Fabrication
Nov 18, 2004 07:51 PM
Sport_Injected
Sep 20, 2004 03:20 AM
sj993
Aug 30, 2004 04:44 PM
