Tranny question HELP
Old Aug 8, 2006 | 06:53 AM
ej8_vtec's Avatar
Default Tranny question HELP
Alright so here's the story, my T2T4 tranny that came with my swap was ran without fluid in it. The tranny locked and the only gear I had was 3rd. We loaded it with tranny fluid and tried to drive it around to maybe break the gears free. Now when the tranny was in the car the only gear I could put it in and out of was 3rd and neutral. Now that the tranny is out of the car and sitting on the shelf I can use the selectors to put it into every gear.. So is the transmission good to put back into the car? Will it be drivable? Or should I take it to a transmission shop and have it rebuilt / looked at, as I was planning to do. Any input would help at this point, I need this tranny back in my car ASAP!
Old Aug 8, 2006 | 08:18 AM
ej8_vtec's Avatar
Anyone have any idea?
Old Aug 8, 2006 | 09:08 AM
rainforest's Avatar
Default Re: (ek2_vtec)
could you move the shifter between 12 45 befor or would it just grind? If you did nothing to the tranny you did not fix it. look at the gears syncros and selector forks you might need to get a manual transmission work is not a guessing game.
Old Aug 8, 2006 | 09:19 AM
ej8_vtec's Avatar
i couldnt even put it into any of the 1,2,4,5 gears i had neutral and 3rd thats it. it didnt grind it just did not move toward or in any of those gears
Old Aug 8, 2006 | 06:34 PM
ej8_vtec's Avatar
bumped!
Old Aug 9, 2006 | 01:10 PM
Gearspeed-Performance's Avatar
Since you have it out of the car...why not open it and see what is bad?
Old Aug 9, 2006 | 04:59 PM
ej8_vtec's Avatar
i dont know how to
Old Aug 10, 2006 | 07:53 AM
ej8_vtec's Avatar
but on some more help/info
Old Aug 16, 2006 | 02:26 PM
ej8_vtec's Avatar
Update I got the case open and this is what it looked like inside... Now I know absolutly(sp?) nothing about transmissions but this one seems to be perfectly fine. No chipping at all, no metal at the bottom or anywhere in the case. Magnets werent covered in much metal at all, just a light layer. Everything spun well, could select every gear. Any of you transmission guru's see anything wrong with it at all???
Old Aug 16, 2006 | 02:27 PM
ej8_vtec's Avatar
sorry for the shitty pics, i dont have a great camera. Let me know if you need to see any other angles or peices of the tranny. Thanks!
Old Aug 16, 2006 | 02:48 PM
Some of the gears seem to have grooves from oil deprivation...can't be certain because of the pics.
Old Aug 16, 2006 | 02:58 PM
ej8_vtec's Avatar
would that cause the transmisson not to work if i were to install it again. I just want to be sure its good to install again or should i have it looked at / rebuilt by someone
Modified by ek2_vtec at 9:27 PM 8/16/2006
Old Aug 16, 2006 | 08:28 PM
ej8_vtec's Avatar
bump
Old Aug 17, 2006 | 06:20 AM
ej8_vtec's Avatar
anyone think its ok to be installed again?
Old Aug 18, 2006 | 02:57 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: Tranny question HELP (ej8_vtec)
can't really see what we need to by the pics you posted.
pull the mainshaft bearing off the top with your hand. take that bearing shim off too. now pull up that thing with the slots that was under the shim...look at the bottom of it for wear and see if it's blackened from severe heating up. also check the synchro hub top and bottom (over 5th gear cone) you kind of have to pull some of that mainshaft stack apart to check for wear and heat discolorations. check the ends of the gear synchro cones that contact the synchro hub tops and bottoms. do that for 3/4 and 5/R. if you take it apart, take notes of the arrangement.
boostinnc
Transmission & Drivetrain
Jan 2, 2010 01:37 PM
Drian
Jul 28, 2004 06:31 PM
