Valve question(does this look o.k??)
Old Aug 8, 2006 | 05:18 AM
Mr.Death's Avatar
Default Valve question(does this look o.k??)
I'm changing my first headgasket and when I pulled off the head I noticed that the 2 exhaust valves on cylinder 2 were open. I set the timing at tdc before removing the head and didi everything by the book thusfar. Is it normal for these valves to be open at this point of rotation on the cam??? I'm new to this so bare with me.
All other valves are closed except exhaust valves#2
Thanks,
Rick
Old Aug 8, 2006 | 08:45 AM
Mr.Death's Avatar
anyone????????
Old Aug 8, 2006 | 08:59 AM
rainforest's Avatar
Default Re: (Mr.Death)
your goof\d tdc cyl 1. means that only the cylinder 1 is at tdc the cylinder 2 is on the exhaust stroke at this point. being that the firing order is 1342.
Old Aug 8, 2006 | 09:12 AM
Mr.Death's Avatar
Default Re: (rainforest)
Ahhh, thank you my friend
MMMGIRL
Engine Machining & Assembly
Oct 19, 2016 08:48 PM
dr3amline
Mar 21, 2013 10:37 AM
JamesB1985
Mar 4, 2013 02:33 PM
HondaKing90
19
Feb 15, 2010 04:38 PM
sony224422
Jan 4, 2008 12:20 PM
