not turning over what so ever
Old Aug 7, 2006 | 08:00 PM
immrtaltchnq's Avatar
Default not turning over what so ever
ok so my car wotn turn over.. at all
all accesories will turn on and my head lights turn on and dont dim
when i push the clutch in and turn the key alls it does is turn accesories on and makes no noise like its even attempting to turn over
i can pop the clutch and it will start
so i replaced the starter
and its doing the same thing
so were do i go from here?
Old Aug 7, 2006 | 08:11 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: not turning over what so ever (immrtaltchnq)
wow, stop being a parts changer, whats your battery voltage?
Old Aug 9, 2006 | 11:29 AM
cashshoes's Avatar
yeah check your battery and you should change your alt to cause most likely your battery whent dead because of your alternator
Old Aug 9, 2006 | 11:32 AM
Dwight Schrute's Avatar
Default Re: (cashshoes)
uhh... did you guys not see that he can turn the headlights on and they're not dim. it's not his battery. can you hear your fuel pump priming. it could possibly be your man relay.
Old Aug 9, 2006 | 11:42 AM
cashshoes's Avatar
yeah it could your battery can have enuff voltage to let radios and headlights work properly but not enuff to start the vehicle considering that a starter takes more volts to run than head lights why do you think if you try starting your car you can try like 6-8 times before the battery is dead rather than leaving your lights on for 3 hours
Old Aug 9, 2006 | 11:46 AM
it would at least try to turn over if he can turn on the headlights. it's not the battery.
Old Aug 9, 2006 | 12:02 PM
del sol1658's Avatar
Default Re: (drewthomas14)
Clutch safety switch?
I had the same problem the other night, car wouldnt turn over, me music, lights, subs etc all worked, had some1 push me and i jump started it, drove home no problem.
Old Aug 9, 2006 | 12:36 PM
EvilPinkEye's Avatar
Default Re: (del sol1658)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del sol1658 &raquo;</TD></TR><TR><TD CLASS="quote">Clutch safety switch?
I had the same problem the other night, car wouldnt turn over, me music, lights, subs etc all worked, had some1 push me and i jump started it, drove home no problem.</TD></TR></TABLE>
either that , or your missing suming with the starter, had the same prob...it was starter...hot wire that sucker to see if it turns.
Old Aug 9, 2006 | 09:06 PM
Default Re: (EvilPinkEye)
yea battery had 12 volts not running starter was running right and everything
it was the neutral saftey switch or w/e.. but i rigged it up to start without the clutch for now until i got some money to fix it
DC5_lov3r
Jan 22, 2016 03:38 PM
r4in
Jan 3, 2014 09:27 AM
stickman78114
Dec 17, 2010 06:31 AM
envee
13
Aug 30, 2007 01:29 PM
Moe
10
Nov 5, 2003 12:02 PM
