D-series PM3-17 head question
Alright so i bought an engine from a local supplier and was told it was a d15b2, i forgot to check when i picked it up, seeing as ive never had a problem from them before.
Well the block says d15b, and the head says pm3-17. I know the usdm d15b's came out of the std, but the ones ive seen have had different heads.
The reason why this question aroused was because on the back of the head near the dizzy there is a cover covering an opening, when ive only ever seen it blocked off by casting.
Any help would be nice, im returning the engine anyways, because i can get another b2 in better condition.
It's the JDM D15B Non-VTEC probably.
D15B[edit]
Found in: 1988 Honda CRX 1.5X (rare)
1990 Honda Civic 25XXT Formula (Japanese Market)
Honda Civic Ferio MX (Japanese Market) EG8
1998–2001 Honda Capa GA4 (Japanese Market) Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm ื 84.5 mm (2.95 in ื 3.33 in)
Compression : 9.2:1
Power : 103 hp (77.23 kW, 105 PS) at 6,800 rpm
Torque : 14.1 kgm (133.4 Nm) at 5,200 rpm
Rev limiter : 7,200 rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : Twin carburetor PGM-CARB/fuel injected
D15B[edit]
See Non VTEC
Found in: 1995–1998 Honda Civic Ferio Vi (EK3, Japanese market)
1999-2000 Honda Civic Vi-RS Bore and Stroke :75,0ื84,5 mm
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.3:1
Power : 130 PS (96 kW; 128 hp) at 7,000 rpm[8]
Torque: 139 Nm at 5,300
Redline : 7,200 rpm
Valvetrain : SOHC, four valves per cylinder
Connecting rod length : 137 mm
Connecting rod big end diameter : 48 mm
Fuel Control : OBD2a
Head Code : P2J-07
ECU Code: P2J (small case ECU)*** AUTO CVT: P2J-J63*** MT P2J-003*** & ***MT P2J-J11***
Piston code : P2J
D15B[edit]
Compression : 9.2:1
D15B[edit]
See Non VTEC
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.3:1
Redline : 7,200 rpm
Head Code : P2J-07
Piston code : P2J
MovingParts
20
May 2, 2007 01:18 PM
