When to shift?
Old Aug 7, 2006 | 05:59 PM
Jhonny Ricer's Avatar
Default When to shift?
Alright so I've got a 1996 honda Civic CX completely stock, When I go out sometimes I like to screw around ((on the track)) Only problem is when Im screwing around I end up ******* up I need to know when to shift in gears wise ive looked for a CX shifting diagram but no luck yet when is redline on this car 7200?
Also does it have a rev limiter when it reaches this point? A few nights ago I was driving and noticed that my car was doing 60 in second gear Yes call me a retard I know I dont know where my mind was but yea any help would be apprieciated!
Old Aug 7, 2006 | 06:01 PM
BlueIntegraBoy's Avatar
Default Re: When to shift? (Jhonny Ricer)
Get an LX cluster. It will have the correct redline on the tach. There's a limiter slightly past the redline.
Old Aug 7, 2006 | 06:06 PM
Slopoke's Avatar
Default Re: When to shift? (BlueIntegraBoy)
If you dont have a tach, just run the car to the limiter in every gear, noting the mph. Then when you're driving hard, just shift right before that mph.
Or just get a tach. lol
Old Aug 7, 2006 | 06:13 PM
aholeb18's Avatar
Default Re: When to shift? (Slopoke)
i'm calling you a retard. is this your first car?
Old Aug 7, 2006 | 06:14 PM
If i get an LX cluster will it still be basically plug and play though?? Does a CX already have the wiring and everything going to the cluster for the tach?
edit: Second first was an automatic trep that some lady came around a blind turn whent into my lane and hit me head on...
Have no prob with you calling me a tard, I just got into the whole honda scene and manual for that matter. Im a noob I'll admit nothing to be ashamed with not knowing everything off the bat everyone has that prob..
Old Aug 7, 2006 | 06:20 PM
SOHC4life 96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer &raquo;</TD></TR><TR><TD CLASS="quote">If i get an LX cluster will it still be basically plug and play though?? Does a CX already have the wiring and everything going to the cluster for the tach?
edit: second first was an automatic trep that had a tach </TD></TR></TABLE>
Yes, it will plug and play.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aholeb18 &raquo;</TD></TR><TR><TD CLASS="quote">i'm calling you a retard. is this your first car?</TD></TR></TABLE>
I'm calling you a retard. Is this your first post?
Old Aug 7, 2006 | 06:23 PM
Default Re: When to shift? (SOHC4life 96)
thanks for the help
Old Aug 7, 2006 | 06:36 PM
Slopoke's Avatar
Default Re: When to shift? (aholeb18)
You're calling me a retard? Or thread starter a retard?
Old Aug 7, 2006 | 06:44 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">
You're calling me a retard? Or thread starter a retard?</TD></TR></TABLE>
I think he's calling you a retard..
at OP:
Ha, happend to me my 2nd or third race, the place where we startd was a clearing on the side of the road (it was in the corner on a bend) and it was dirt, I overspun my tires and pulled ahead, looked over my shoulder to see where he was, when I looked back I was HAMMERING the rev limiter & the wheels already caught :-P Oh well, **** happens...
Anyways..
I'd buy a tach or a guage cluster with a tach, either way, get a tach, then shift at like 4k daily driving or so... You have a limiter around 7400 maybe, 7200, somwhere around there, so u wont' dick slap the engine...but still running the engine that hards increases the chances of you throwing a rod really bad (the more RPM's you run ur engine, the more wear and tear on the engine it is)....so if you redline it everytime u drive, it might only last 1/3 as long opposed to if you shifted at 4k and only redlined it maybe once a day or once every 2 days....just an example though, but I think my point's illustrated, basically u won't blow the engine from revving it too hard once because there is a rev limiter, but if u keep hammering it up there in high RPM's close to the redline you're going to put so much wear & tear on the engine it won't be long before ur looking at a rod w/ the engine still together...
Old Aug 7, 2006 | 06:53 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: When to shift? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm calling you a retard. Is this your first post? </TD></TR></TABLE>
There's a post counter for that
Old Aug 7, 2006 | 07:34 PM
92redhatch's Avatar
i think with the cx motor you shouldnt go past like 6200rpm. Atleast when i had my cx motor that thing wanted to die after 5500rpm.
Old Aug 7, 2006 | 07:49 PM
Default Re: (92redhatch)
well lets put it this way my car was in second gear going 60 and couldve gone more but i freaked and shifted cause i didnt know if i was pushing the rpms and didnt know if it had a rev limiter
Old Aug 7, 2006 | 07:55 PM
Vtecgrrl's Avatar
If I remember correctly, your car's gears are similar to mine (VX) When I run it when I'm dicking around I shift around 5200. Anything higher and you're losing power. daily driven I just keep my steady speed so I'm around 2k...my car doesnt like chugging at 1500 or lower...i usually shift around 4k.
And my car will do 70 in second, at around 6k. my gears are long, think your's are too.
*edit haha sorry, I may be horribly wrong on my post...didnt notice the yr of your car til just now
Old Aug 7, 2006 | 07:56 PM
Default Re: (Jhonny Ricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer &raquo;</TD></TR><TR><TD CLASS="quote">well lets put it this way my car was in second gear going 60 and couldve gone more but i freaked and shifted cause i didnt know if i was pushing the rpms and didnt know if it had a rev limiter</TD></TR></TABLE>
You will get terrible gas mileage if you're in 2nd at 60. Shift to 5th.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecgrrl &raquo;</TD></TR><TR><TD CLASS="quote">If I remember correctly, your car's gears are similar to mine (VX) When I run it when I'm dicking around I shift around 5200. Anything higher and you're losing power. daily driven I just keep my steady speed so I'm around 2k...my car doesnt like chugging at 1500 or lower...i usually shift around 4k.
And my car will do 70 in second, at around 6k. my gears are long, think your's are too.</TD></TR></TABLE>
His car has a Y7. It will make power after 5200.
Old Aug 7, 2006 | 08:12 PM
wheelmanbg's Avatar
Default Re: (BlueIntegraBoy)
What is the need to rev your motor to 4k when daily driving????
My car doesn't see more than 2.5k-3k unless i'm ******* around
Old Aug 7, 2006 | 08:13 PM
TheNasty0ne's Avatar
Some mis information here on this thread.
First of all you would want to get a EX guage cluster or Si, CTR...etc not an LX lol...
CXs came with D16y7 motors with a stock redline of 7200 RPM and yes there is a rev limiter as long as the ECU wasnt modded or chipped in anyway.
y7s will make power to 5000-5500 RPM so shift at 6k?...
Old Aug 7, 2006 | 09:57 PM
Default Re: (SkAnK_aSS_BryAN!)
might as well get a CTR cluster i whant to do the conversion BUT i need to find it as cheap as possible before i do that ****
P:s;on a website i found a cluster that was all red and black they said it was ctr i think it was passwordJDM.com prob is werent they yellow neddles wit red numbers and had a caution orange around the 8k to 9k rom?
Old Aug 7, 2006 | 09:59 PM
FalkenSiR's Avatar
just get a m4d tyte 5"tach yo
ctr would be nice, but your car is overall stock...
Old Aug 7, 2006 | 10:02 PM
Default Re: (fast95eg8)
But it isnt staying stock, It should be close to CTR by the end of this year and will have the engine.
Old Aug 7, 2006 | 10:05 PM
Jason-'s Avatar
Ive got an ek ex gauge cluster with the ctr cf bezel. Make me an offer and We'll go from there. Everything works.. i'll even go test it on a buddies ek and take pics for you.. just to make sure.
-Jason
Old Aug 7, 2006 | 10:14 PM
Default Re: (Jason-)
rather have the type r cluster though thanks
Old Aug 7, 2006 | 10:15 PM
Jason-'s Avatar
Get the ek4 cluster. Amber on amber or whatever it is. SICK! Just not the CDM or EDM one. JDM Ek4 SiR.
-Jason
Old Aug 8, 2006 | 08:59 AM
cashshoes's Avatar
i shift at 10 grand try that
Old Aug 8, 2006 | 06:31 PM
Default Re: (cashshoes)
Or how about I try doing a burn out on your face!!
Old Aug 8, 2006 | 06:49 PM
del_slow420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cashshoes &raquo;</TD></TR><TR><TD CLASS="quote">i shift at 10 grand try that </TD></TR></TABLE>
i do that to b16 power baby
