ECU codes
Old Aug 7, 2006 | 05:38 PM
4CDFED's Avatar
Default overheating
i have a built ls/vtec. its throwing a 10 and 41 code. intake temp. and primary oxygen sensor "Heater"... i had a pin hole leak in my radiator hose i fixed that and is was driving fine for a couple days.. today it overheated like crazy... any help please??
Old Aug 7, 2006 | 05:45 PM
vsmhatched's Avatar
Default Re: ECU codes (colombian cartel)
check and see if your getting voltage to the o2 and IAT sensor
Slopoke's Avatar
Default Re: overheating (colombian cartel)
Replace your intake temp sensor and o2 sensor.
For the overheating, check you coolant level. Then check to see if your thermostat is opening and if your radiator fan is coming on.
Old Aug 7, 2006 | 05:49 PM
4CDFED's Avatar
Default Re: overheating (Slopoke)
how would i know if my thermostat is not opening??
Old Aug 7, 2006 | 05:55 PM
Slopoke's Avatar
-start your car
-feel the top radiator hose, it should get hot.
-once the thermostat opens, the lower radiator hose will get hot.
-if the lower hose doesnt get hot(be patient, it takes a while), then your thermo isnt opening(that means its bad).
*make sure you watch your temp gauge while your doing this. Make sure your car doesnt overheat while you're waiting.
Old Aug 7, 2006 | 05:59 PM
4CDFED's Avatar
thanks a lot dude ill try that..
Old Aug 7, 2006 | 07:46 PM
4CDFED's Avatar
well i tried that and it wasn't the case... both radiator hoses got quite hot.. also i reset the ecu and it still codes 10 and 41... any other ideas???
Old Aug 7, 2006 | 07:56 PM
4CDFED's Avatar
and where might the IAT sensor on my ls/vtec be located??
Old Aug 8, 2006 | 09:43 AM
Slopoke's Avatar
The sensor looks like this:
Old Aug 8, 2006 | 03:32 PM
vsmhatched's Avatar
most likely the intake manifold
Old Aug 8, 2006 | 04:20 PM
4CDFED's Avatar
Default Re: overheating (GreyDel)
ok cool.... So do you just pull off the plug, then the sensor unscrews and comes right out??
Old Aug 9, 2006 | 06:03 PM
vsmhatched's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by colombian cartel &raquo;</TD></TR><TR><TD CLASS="quote">ok cool.... So do you just pull off the plug, then the sensor unscrews and comes right out?? </TD></TR></TABLE>
yeah, should be 2 phillips head screws...
bigchris2000
Jun 3, 2010 09:00 AM
Bruce Banner
Oct 17, 2009 06:53 PM
Rival23
Oct 22, 2003 08:48 AM
92SiHatchie
31
Jul 26, 2003 10:54 AM
BluLuder
Dec 12, 2001 09:47 AM
