SOHC Experts, need some info...
Old Aug 7, 2006 | 05:02 PM
Mike K's Avatar
Default SOHC Experts, need some info...
So I bought a 93 DX hatch for a pretty decent price.. it's got the stock D15B7 under the hood, but it's got a serious ring problem. goes through a quart of oil in less than 200 miles. i think the last owner might have run the oil level a little low, and now this thing has a knock when you first start it.
anyway, instead of throwing some rings and bearings in it, i picked up a d16y7 from a 98 DX. i was planning on just throwing this longblock in there.. but before i begin, i wanted to see if anyone knows..
1- are the bolt patterns for the intake manifold the same?
2- is the water passage the same at the manifold?
3- will the b7 distributor work, as far as timing is concerned? (i remember a friend of mine had an issue with this when he was doing mini-me.)
worst case scenario, i could either re-pin the distributor or just swap the guts over.. but it'd be rad if i could just use the existing d15b7 dizzy.
thanks!
Old Aug 7, 2006 | 05:06 PM
Bense's Avatar
Default Re: SOHC Experts, need some info... (Mike K)
1. they're the same
2. they're the same but what year is the y7?
3. the only different dizzy bolt pattern is 92-95 vtec. d15b/d16z6/d15z1 use the "vtec" bolt pattern. all 88-91, nonvtec-92-95, and all 96-00 dizzys have the same bolt pattern.
Old Aug 7, 2006 | 05:15 PM
Mike K's Avatar
Default Re: SOHC Experts, need some info... (Bense)
the y7 is from a 97 or 98. i can find out for sure tomorrow.
ok, so the bolt pattern for the dizzy is the same.. but i am wondering if the angle is the same at the cam. i was going to just put both motors at tdc, and pull the caps off the dizzy's.. but if it's only a few degrees, you won't be able to see that, and a few degrees at the motor is major. i just want to be 100% sure.
so you think this is a no problem, straight bolt-in? should be done in like 3 hrs?
Old Aug 7, 2006 | 05:33 PM
hondacivic946's Avatar
well i have a y7 in my car with the z6 intake main and everything went in good
dc2_build
Northern California (Sales)
Jul 6, 2013 08:51 PM
gsr_b20b
Mar 1, 2012 10:03 AM
panchlow
Sep 12, 2011 08:13 PM
Schaz
May 31, 2005 05:25 PM
jeff91z6
12
Aug 8, 2002 07:37 PM
