OBX LSD FAQ
Old Aug 7, 2006 | 04:21 PM
Bense's Avatar
Default OBX LSD FAQ
Just trying to consolidate all the OBX LSD questions into one thread. Please post them in here for search purposes. Plus it will help to have all the info in one convienient thread rather than searching through 5-6 threads in each seperate subforum
HOW TO: Field strip an OBX LSD
https://honda-tech.com/zerothread/1752849
***OBX LSD disassembly questions***
https://honda-tech.com/zerothread/1381146
obx lsd question
https://honda-tech.com/zerothread/1713950
more to come
Shim info
http://www.d-series.org/forums...nt=73
Modified by Bense at 6:58 PM 11/22/2006
Old Aug 7, 2006 | 04:29 PM
Bense's Avatar
Default Re: OBX LSD FAQ (Bense)
just typing from memory about everything I know about the d-series.
it's a attempted copy of the quaife lsd. the axle removal issue that surfaced a while ago has been resolved with a design revision. On the d-series, the unit is thicker than it should be, and to properly shim it, there's not a oem shim thin enough.
The solution is to use a b-series oil control ring as a shim to get the proper clearances
more info to come
Old Aug 8, 2006 | 10:39 AM
purestreetracer's Avatar
well i have had an OBX lsd for like 3 1/2 weeks and nothing wrong..thats ripping on it.
Old Aug 9, 2006 | 02:08 PM
Enzo Speed's Avatar
Default Re: OBX LSD FAQ (purestreetracer)
Anyone know a part # for the oil ring?
Modified by Enzo Speed at 12:57 AM 8/10/2006
Old Aug 12, 2006 | 12:24 PM
mike93eh2's Avatar
cant just buy the oil ring. gotta buy at a ring set for a piston. just get a used one from someone for nothing.
Old Aug 26, 2006 | 05:53 PM
BlueCrxNC's Avatar
I actually took two OBX LSD's to a machine shop to have the carrier milled down to re-use the OEM shim. They milled down the face of the LSD where the Differentail Bearing would rest (RING GEAR SIDE! otherwise your LSD would sit high in the case and cause other clearance issues!)
Don't remember the spec we shaved but I can always look it up in my papers. It worked out that I could reuse the original shim that was in each tranny case; even though I only measured one LSD/case combo. So I found the exact manufacturer error for the one's I purchased.
Old Aug 28, 2006 | 07:00 PM
spooledhonda's Avatar
* B A N N E D *
ok so i bought an obx lsd for my LS tranny, is it a derect replacment?
Old Aug 28, 2006 | 07:41 PM
Enzo Speed's Avatar
Default Re: (spooledhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooledhonda &raquo;</TD></TR><TR><TD CLASS="quote">ok so i bought an obx lsd for my LS tranny, is it a derect replacment?</TD></TR></TABLE>
Yep. We're all talking about modifying it and re-shimming it because we like wasting our time. It's really a perfect direct fit.
/******* sarcasm
Old Aug 29, 2006 | 03:06 PM
* B A N N E D *
ok so then why are you shimming it and milling it????
Old Sep 2, 2006 | 11:13 PM
siblues's Avatar
sarcasm
Old Sep 3, 2006 | 02:44 PM
Combustion Contraption's Avatar
wow
Old Sep 7, 2006 | 07:44 AM
* B A N N E D *
thought so
Old Sep 9, 2006 | 09:29 PM
RagingAngel's Avatar
Bense,
I think this one is pretty good.
https://honda-tech.com/zerothread?id=1524643
Old Sep 12, 2006 | 08:50 AM
ZacCarter's Avatar
Old Sep 17, 2006 | 06:26 PM
Smokinsax's Avatar
The Boot
Old Sep 23, 2006 | 01:20 PM
Mista Bone's Avatar
D Tranny Guru
of the 7 OBX's I've installed in D series trannys, the diff has been .5mm-.7mm too wide.
I'm in the process of having shims made @ .030" and .020" thick. If they work out, I should be able to sell a bunch. The tooling costs is what is gonna cost alot!
Old Sep 23, 2006 | 02:30 PM
mike93eh2's Avatar
mine had the perfect clearance with a b-series oil control ring...
a d-series z6 tranny btw.
Old Sep 23, 2006 | 05:43 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (mike93eh2)
I've been doing the same, .020"/.5mm ring, but some are a little loose, Plus I'd prefer something a little wider to support the race correctly.
If you goto pop the axle out, ALL force is on the little shim......you can crack the case doing so.
Old Sep 25, 2006 | 07:32 AM
sackdz's Avatar
Default Re: (Mista Bone)
anyone wants a used b series oil ring for $1 pm me.
Old Oct 6, 2006 | 12:53 PM
eg:R's Avatar
mine have problem taking out pass. side axle. b series
Old Oct 12, 2006 | 03:43 PM
2 0 3's Avatar
Default Re: (eg:R)
in a B Series hydro case
Disassembled, re-stacked springs, assembled with grade 8's. So Far so good!
both axles have been in and out, pass side 4 times now
Old Oct 22, 2006 | 08:38 PM
661rex89si's Avatar
all i wanna know is if the obx lsd will fit my 89 si l3 tranny or do i need different bearings.
Old Oct 25, 2006 | 04:33 PM
Bense's Avatar
Default Re: (661rex89si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 661rex89si &raquo;</TD></TR><TR><TD CLASS="quote">all i wanna know is if the obx lsd will fit my 89 si l3 tranny or do i need different bearings.</TD></TR></TABLE>
Yes it will fit your si trans. Your original bearings can fit. Or if you want some new ones, you can order k20 differential bearings
Old Oct 31, 2006 | 08:10 AM
ae92sprinter's Avatar
Default J1 Diff question
Hey
hopefully a quick one for ya. lookin into investing in an obx lsd for my b16a OBD1 integra it has a J1 gearbox guy im buyin the diff off says iy will fit the Y1 but is unsure if the same diff will fit the J1.
Cheers
Mul
Old Nov 6, 2006 | 05:42 AM
b16civster's Avatar
Default Re: J1 Diff question (ae92sprinter)
DO THEY MAKE A DIFF FOR THE S1 JDM CABLE TRANNY YET??????????????????????????????????????????????? ?????????????????????????????????????????????????? ???????????????????????????????????????????
I NEED ONE ASAP
PAGE 2 OWNS
