Safe mode solid code tried new ecus HELP ME PLEASE
Old Aug 7, 2006 | 02:24 PM
SinglecamMitch's Avatar
Default Safe mode solid code tried new ecus HELP ME PLEASE
I have a 92 hatch w/ a p28 ecu chipped and tuned with chrome. My car would cut out when i hit large bumps and sometimes completely shut off throwing a solid code. Finally the car gave up and shut off... i thorw a solid code now but tried new chips, ecus, dizzys, changed my ignightor, plugs, wires, cap,rotor, and was wondering if it could be my resistor box. The plugs come out black and the car is idling like poop and seems like its missing when i try to rev it up. It wont go past 3800 rpms. Im dazed and confused and need some help what could my problem be. Thanks - Mitch
Old Aug 7, 2006 | 02:27 PM
car runs great with stock injectors and ecu... so im sure it has to do something with the fuel or injectrs
Old Aug 7, 2006 | 02:40 PM
Syndacate's Avatar
I wonder if it went into limp mode...
I don't know much about this though so u'll need other pple's input
Bump 4 u
Old Aug 7, 2006 | 02:45 PM
yea it went into limp mode...
Old Aug 7, 2006 | 03:23 PM
hott95ej2's Avatar
Default Re: (SinglecamMitch)
what gas are you using in that thing?
Old Aug 7, 2006 | 03:27 PM
running 93 swapped plugs still ran like ****... i just put in a new resistor box and still the same thing... im so fustrated
Old Aug 7, 2006 | 03:28 PM
hott95ej2's Avatar
ingnition timing?
Old Aug 7, 2006 | 03:31 PM
tdc everything is fine with the timing cuz i put the stock injectors and ecu in and it drives like a champ
Old Aug 7, 2006 | 03:33 PM
hott95ej2's Avatar
is dist turned all the way back?
Old Aug 7, 2006 | 03:39 PM
nope everything is fine with the dizzy... changed the ignightor, cap, rotor, wires, and plugs
Old Aug 7, 2006 | 03:44 PM
hott95ej2's Avatar
I really cant tell you what to do without a visual, but id say you need to pull some ignition timing out of it
Old Aug 7, 2006 | 03:47 PM
yea i just got off the phone with a friend with the same motor and ima try his dizzy to c what i can pull out of it... thanks for the help
Old Aug 7, 2006 | 03:51 PM
hott95ej2's Avatar
yea it def sounds like your car is running a lil rich but better rich than lean, dont burn those rings up
Geis
Dec 17, 2015 11:20 AM
akura404
Dec 1, 2006 07:49 AM
turbohb91
Mar 30, 2005 07:53 AM
c_buz
10
Mar 5, 2005 05:52 AM
mugenintegra16
Jan 24, 2004 02:29 PM
