LSVTEC probs please help!
Old Aug 7, 2006 | 01:57 PM
spoonfedjdm's Avatar
Default LSVTEC probs please help!
ok so i got a obd0 ls block obdo b16 head arp head studs and a golden eagle lsvtec kit the motor is in my car ang runs and drives got, but when i put the right amount of oil in it just 4 quarts the car will be ok but when i go around a corner fast or just driving it will SMOKE hella bad but only 4 ten seconds then it'll b fine, anybody else have this same prob? please help!!!!
Old Aug 7, 2006 | 11:29 PM
Default Re: LSVTEC probs please help! (spoonfedjdm)
bump
Old Aug 9, 2006 | 10:45 AM
CanuckCRX's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonfedjdm &raquo;</TD></TR><TR><TD CLASS="quote">ok so i got a obd0 ls block obdo b16 head arp head studs and a golden eagle lsvtec kit the motor is in my car ang runs and drives got, but when i put the right amount of oil in it just 4 quarts the car will be ok but when i go around a corner fast or just driving it will SMOKE hella bad but only 4 ten seconds then it'll b fine, anybody else have this same prob? please help!!!!</TD></TR></TABLE>
Well does it smoke when you go around a corner fast or when your just driving? If it only does it when your cornering, and the smoke is coming from the engine bay I would say check your valve cover gasket for leaks. If it comes out the exhaust when you corner hard, I have no idea.
Old Aug 9, 2006 | 02:27 PM
Default Re: LSVTEC probs please help! (CanuckCRX)
yeah it only smokes out the exhaust sometimes when i corner hard or just driving then it stops.
Old Aug 9, 2006 | 02:32 PM
bump
Fallriverb16
Oct 18, 2016 03:56 AM
The Si
Feb 8, 2007 03:29 AM
badboy69385
Jun 24, 2006 08:34 PM
iheartmyej8
May 9, 2006 10:11 AM
=ITRpoweredEK9=
Jan 23, 2006 12:25 PM
