Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Reduse shift throw, Cut it in half literally?
Old Aug 7, 2006 | 12:57 PM
kevinm30's Avatar
Default Reduse shift throw, Cut it in half literally?
OK i know this is kinda a stupid question but I really like the look of a short lever shifter "manual". Like in some cars where the shifter barly sticks out past the consel. Im thinkin about takin it apart and cutin the shift lever in 1/2. I would just like get some peoples opinions on it Im sure it would reduce shift throws because its closer to the center point, i just dont know if its a good idea and if it will be easy to reach.
Old Aug 7, 2006 | 01:11 PM
Type X's Avatar
Default Re: Reduse shift throw, Cut it in half literally? (kevinm30)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinm30 &raquo;</TD></TR><TR><TD CLASS="quote">OK i know this is kinda a stupid question but I really like the look of a short lever shifter "manual". Like in some cars where the shifter barly sticks out past the consel. Im thinkin about takin it apart and cutin the shift lever in 1/2. I would just like get some peoples opinions on it Im sure it would reduce shift throws because its closer to the center point, i just dont know if its a good idea and if it will be easy to reach.</TD></TR></TABLE>
There are so many things i want to say now...yet i will sum it up with this
Old Aug 7, 2006 | 01:21 PM
tooann's Avatar
Default Re: Reduse shift throw, Cut it in half literally? (Type X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">There are so many things i want to say now...yet i will sum it up with this
Old Aug 7, 2006 | 01:36 PM
RWatters's Avatar
It's not going to shorten your shifts.
Old Aug 7, 2006 | 01:40 PM
K20Z3Si's Avatar
lol, well put
Old Aug 7, 2006 | 01:56 PM
Nighthawk R18's Avatar
me and my friend did this on his GTi mk4
didnt really reduce the throw, but it takes less movement to shift since your shifting closer to the base. you can do it if your planning on buying a short throw. then if u eff up. your gunna change it anyway.
Old Aug 7, 2006 | 02:50 PM
dREsTrUcTiON's Avatar
Default Re: Reduse shift throw, Cut it in half literally? (THiNK s2k)
Short answer: don't do it.
Old Aug 7, 2006 | 04:24 PM
95turbodteg's Avatar
buy a short shifter from comptech or neuspeed. there are so many things wrong with ur original post. everyone agrees... DONT DO IT! do u know how to thread the shifter itself to fit the **** back on? it wont reduce throws, so its just for aesthetics. bad idea. spend $70 and get a comptech shifter. not shorter looking, but shorter throws
Old Aug 7, 2006 | 06:37 PM
Miracle's Avatar
Default Re: (95turbodteg)
Simply put, if you do not change the point at which the cable attaches to the lever, you do not shorten your shift throw any.
Old Aug 7, 2006 | 06:42 PM
ScuDC5's Avatar
the length of the shaft doesn't reduce the throws. look at the short shifter adapters. They don't touch the shifter rod. If you want to ghetto rig it for a shorter shifting stick then go ahead and cut and super glue it, but when you mess up, you're stuck with an expensive replacement part.
ITRex
12
Sep 2, 2007 03:23 PM
MrPotatoeHead
Apr 23, 2006 04:12 PM
spicoli
17
Sep 28, 2005 09:08 PM
TSAngry
Feb 19, 2004 09:12 PM
HatchBox
10
Jun 11, 2002 05:53 PM
