need help with gasket thickness for my build!
Old Aug 7, 2006 | 12:57 PM
psegs80's Avatar
Default need help with gasket thickness for my build!
K so I got a decked b16a block and i balanced it's stock crank and rods with ARP bolts and chose PCTX pistons (81.25mm civic type r) they are .020" out of the hole! I have a B16B head that has been milled .010" and I opened up the combustion chambers to 82mm so the the compression height of my pistons never come in contact!
Now the only consern that I have is my domes coming in contact with the valves!!!!
(I know builders normally recommend 0.035" of clearence so that the pistons compression height never comes in contact with the head cause rods can strech about 0.030" or so...but I don't have that concern since my combustion chambers have been opened)
So should I go with .036, .040, .045 or .051: Head gasket!
Help and Thanks for any imput!!!
Old Aug 7, 2006 | 05:08 PM
psegs80's Avatar
Default Re: need help with gasket thickness for my build! (psegs80)
Bump on how much the valves come down with Skunk2 stage 1 cams???
Old Aug 8, 2006 | 05:00 AM
d16dcoe45's Avatar
What are you worried about if you don't have any quench? You probably have alot of room before the side of the piston taps the chamber.
Old Aug 8, 2006 | 06:09 AM
Davep's Avatar
if you're out of the hole .020" you might want to get that back along with the oem .030" and go for the .051" to be safe. you could alway clay it and check for sure.
Old Aug 8, 2006 | 06:22 AM
ne3ek's Avatar
Default Re: need help with gasket thickness for my build! (Davep)
where can you get thinner headgaskets? who sells them? or are you guys just pulling layers off stock ones?
Old Aug 8, 2006 | 07:27 AM
Davep's Avatar
Default Re: need help with gasket thickness for my build! (ne3ek)
Cometic has lots of options for honda head gaskets
http://www.cometic.com/
Old Aug 8, 2006 | 07:52 AM
ne3ek's Avatar
ya i had a cometic on my ls/v but i only see different bores
Old Aug 8, 2006 | 08:38 AM
Davep's Avatar
they have different ones, call them
Old Aug 17, 2006 | 03:57 PM
psegs80's Avatar
Thanks for the replies guys, I'm not worried about pistons side walls hitting the combustion chamber cause I opened it up 82mm and my pistons are only 81.25mm! What I was worried about was valves coming in contact with my domes but I figured it out by mesuring how much the valves came down with my cams and I opted for a cometic 0.040" thick HG with a 83mm opening so that it wouldn't grabs some compression ( gasket needs to be 0.030" wider then combustion chamber opening)
Thanks Pat
ben h
15
Apr 24, 2012 01:08 PM
fr3dy_1
Nov 23, 2006 02:04 PM
T.Slick
Mar 4, 2006 05:10 PM
gundamgsr
May 23, 2004 11:14 PM
