New Shims on OEM Brake pads?
Old Apr 24, 2002 | 10:21 AM
onyx00's Avatar
Default New Shims on OEM Brake pads?
I no longer have the simhs that came with my OEM pads; does anyone remember if you get new ones with the new pads from the dealer or if I need to order new ones seperately? If so, anyone got a part #?
Old Apr 24, 2002 | 11:47 AM
onyx00's Avatar
Default Re: New Shims on OEM Brake pads? (onyx00)
So no one knows? Come on guys
Old Apr 24, 2002 | 11:59 AM
typer_801's Avatar
Do you really need them?!? When I installed my R4S pads I just liberally applied anti-seize the backing and to friction points on the caliper mounting. No squeaking in 15K miles of driving. I would think the OEM pads would be less likely to squeal than an aggressive aftermarket pad too.
In other words, I don't think you need to waste your money.
Old Apr 24, 2002 | 02:01 PM
Toda Party's Avatar
Default Re: New Shims on OEM Brake pads? (typer_801)
when i got my pads from Mike K they came w/ the shims.
FYI - i just used the new shims w/o anti-seize and im not squeaking...
[Modified by Toda Party, 3:02 PM 4/24/2002]
Old Apr 24, 2002 | 03:15 PM
onyx00's Avatar
Default Re: New Shims on OEM Brake pads? (Toda Party)
did you use the Molykote M77 (sp?) that came with the pads, or did you just use nothing?
Old Apr 24, 2002 | 03:57 PM
Toda Party's Avatar
just removed the old pads, put on the new ones and called it a day
from what i gathered when i was asking ?s around here, its recommended but not necessary (could lead to squealing but im ok thus far)
Old Apr 24, 2002 | 04:27 PM
SwiftTypeR's Avatar
New User
i just installed some endless pads on my friends car with no anti-squeel compound and his brake pads dont squeel at all.
Old Apr 24, 2002 | 05:08 PM
Isaac's Avatar
New User
Default Re: New Shims on OEM Brake pads? (SwiftTypeR)
Just apply any anti-squeel compound and don't worry about it. Plus, the squeeling will let the big *** SUV's and the like know that you are around. =P I'm used to my R4-S's squeaking.......
Old Apr 24, 2002 | 07:57 PM
Stock R's Avatar
Default Re: New Shims on OEM Brake pads? (Waxing "The Carrot")
can u guys name some anti-squeel brands so i know what to buy?
STREETFIGHTER50
Honda Civic (2006 - 2015)
May 30, 2012 05:23 PM
iwantspeed
Honda Civic (2001 - 2005)
10
Oct 13, 2006 11:42 AM
hondaracin24
Nov 19, 2004 02:48 PM
spd18
Jul 24, 2003 02:14 PM
ArchAngel Sabastian
Jan 4, 2003 06:23 PM
