Built LS bottom end, recommendations for head, and injectors?
Old Aug 7, 2006 | 08:25 AM
slambedcivic's Avatar
Default Built LS bottom end, recommendations for head, and injectors?
Setup:
LS Block, Block Gaurded, Eagle Rods, SRP 8.5:1 81.5mm Pistons, and ACL Bearings.
Im going to be running a t3/t04e turbo around 15 or so PSI with a GM 3 Bar. Staying @ or under 7k redline on Uberdata.
Question 1: Can I run a stock head setup or should i upgrade to some stronger springs, valves, retainers and the such. And with an 81.5mm Bore will I be safe with a 82mm headgasket.
Questions 2: Would I be safe with 550s?? or should I go bigger?
Any questions please ask as I am open to an and all help/criticism
Old Aug 7, 2006 | 02:27 PM
atg1290's Avatar
Default Re: Built LS bottom end, recommendations for head, and injectors? (slambedcivic)
Bump for a fellow ls..
Old Aug 7, 2006 | 04:31 PM
zccr-xsi's Avatar
why dont u go ls vtec then boost it?
Old Aug 7, 2006 | 04:39 PM
Default Re: (vteckillenzc)
simply because that would be an additional 600 bucks AT LEAST for me to do so. i dont want to spend the money for one, and i would like to be set apart from the rest. ive run non-vtec for a while now and im pretty happy with it.
Old Aug 7, 2006 | 04:40 PM
Default Re: (slambedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">VTEC! just another thing to get pissed off at when it doesnt work!</TD></TR></TABLE>
taken from your sig.....
Old Aug 7, 2006 | 05:28 PM
atg1290's Avatar
Yeah too many people jsut wanna hop on the bandwagon with vtec...I think non-vtec can be just as fun.But to stay on topic, i would upgrade the valvetrain. For the injectors i think 550 would be more than enough what are you # goals?
Old Aug 8, 2006 | 07:51 AM
Default Re: (atg1290)
300 ish
little white
11
Jun 11, 2008 06:26 PM
slambedcivic
Aug 8, 2006 07:48 AM
00b18b
12
May 30, 2004 05:25 PM
Mr.DC2TurBo
Mar 23, 2004 06:03 PM
