crx hf fuel system same as the rest?
Old Aug 7, 2006 | 02:40 AM
jessevtec's Avatar
Default crx hf fuel system same as the rest?
is the fuel system the same as say a dx or si? or is it weaker? will it be adequate for a b series?
Old Aug 7, 2006 | 03:13 AM
davens's Avatar
Default Re: crx hf fuel system same as the rest? (jessevtec)
Off the top of my head...the fuel tank is smaller (10.5, maybe 10.6?).
Maybe the lighter chassis will offset less fuel but I'll bet you have to fill up 40-50 miles sooner than a Si or DX.
I remember reading about a guy with a HF that put in a 25 gallon tank. Went forever between fill-ups.
Anyway, if you're worried about future plans...buy a fuel pressure gauge. They're relatively cheap(I got mine for under $50) and pretty easy to install(20 minutes, literally). This will be how you determine if the fuel system is delivering or not.
Old Aug 7, 2006 | 05:40 AM
HT Chaplain's Avatar
Loved
Default Re: crx hf fuel system same as the rest? (davens)
everything is the same except the HF has a smaller fuel tank
Old Aug 7, 2006 | 07:08 AM
92integra_gs's Avatar
Default Re: crx hf fuel system same as the rest? (HT Chaplain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain &raquo;</TD></TR><TR><TD CLASS="quote">everything is the same except the HF has a smaller fuel tank</TD></TR></TABLE>
its the tranny and the way you drive that provides the MPG
Old Aug 10, 2006 | 05:10 AM
njcrxsi's Avatar
i heard the 88-89 hf injectors were smaller then the standard 240cc,something like 180cc,, is that true?
Old Aug 10, 2006 | 05:11 AM
ludesrv's Avatar
Default Re: crx hf fuel system same as the rest? (JohnnieChimpo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">The return line is bigger diameter. I swapped a HF regulator onto a GRS engine and the car runs fine.
I'm 95% certain the fuel pump and injectors are the same as an Si.</TD></TR></TABLE>
A real GRS eh?
Mike91204
Feb 17, 2013 08:20 AM
dpine
Mar 29, 2007 08:50 PM
niceguy12
Jan 3, 2005 03:54 PM
agreziv89ef-8
May 10, 2004 05:57 PM
