Chipped P28 problems
Old Aug 6, 2006 | 11:39 PM
mesmvc2's Avatar
Default Chipped P28 problems
Well I recently baught a chipped P28 online, it has a 02 heater code that never turns off, could it be that the sauttered the chip wrong and that is what is causing the light not to turn off, I already tried to disable it using uberdata. I am certain that it is the computer because i tried the chip on a friends chipped P28 and the check engine light went away. Any help would be greatly appreciated.
Old Aug 7, 2006 | 03:03 AM
non-VTEC's Avatar
Default Re: Chipped P28 problems (mesmvc2)
maybe the chip programed into the P28 is bad.
you can open the case for the ECU and switch the chip and try again.
iamalex1212
Feb 6, 2009 03:26 PM
redline23
Sep 2, 2007 01:49 PM
99B16Si
Feb 24, 2004 07:30 AM
